2 parter or so
1st) Is there a crank position sensor on a 95 Honda Civic
2nd) Mind you not being a mechanic I recently installed a D16Z6 in a shell I purchased just before winter last year and I am having trouble getting it to run. Sounds like it wants to run when I turn the key but it doesn't turn over.
I hear the fuel pump kick in and the fuel pressure gauge reads around 32. I am getting fuel thru the rail but not sure that the injectors are pulsing. I know that the engine will fire up and run as I sprayed starter fluid into the intake and it fired up no problem.
So my thoughts are cps or injectors not pulsing( I did a volt test on the injector 12.6)
Whats my next move?
Where is the cps?
Is there a way to test the injectors w/o pulling the entire rail?
Whats my next move?
Where is the cps?
ATS*Mark
Aug 7, 2004 10:12 AM
