good chipped ecu for temporary use to get to the dyno
Do you just want a base map? There are a lot of companies that offer basemaps so that you can run the car. Phearble, xenocron, probably many others. They can get you a base map if you send them your settings. Probably find someone on here.
ya just a base map so i can brake the motor in and get it to the dyno without melting a piston and so i know it runs
gofastcrx
Dec 28, 2006 08:13 AM
