91 crx si black smoke
Old Oct 7, 2013 | 04:21 PM
linkfan665's Avatar
Default 91 crx si black smoke
I have a 91 crx si with a new head and its blowing black smoke when I rev it up I pulled the exhaust manifold off and the number 1 exhaust port is wet. Just want to see what yall think im thinking leaky injector??
Old Oct 7, 2013 | 04:41 PM
Freemananana's Avatar
Default Re: 91 crx si black smoke
Man, first post as a trial user. Definitely try google first.
But I will answer. The cause of smoke based on color:
Blue: Oil
Black: Fuel
White: Coolant
Sound like you do have a bad injector. I would not rev it too much until you figure out why your injector is pumping too much fuel. It is probably stuck open, clogged, ect.
Old Oct 7, 2013 | 05:20 PM
linkfan665's Avatar
Yea I see that is where I'm suppose to post at my bad... I'm a super newb at fourms .
Could you send my a link to were I'm suppose to post?? It would be greatly appreciated!
Old Oct 8, 2013 | 03:57 AM
fallrivercolin's Avatar
I think he was just suggesting you google/search the forums for your answer before you post a new thread. Is your car mis-firing noticeably? I would change that injector to another cylinder and see if the problem follows the injector. If it doesn't, and your having misfire issues, you may be looking at a burnt valve.
Old Oct 8, 2013 | 05:12 AM
Before you go burnt valve: Remove the plug and let the fuel evaporate. Shouldn't take long. Try new spark plugs, try moving the plugs from cylinder to cylinder. Could also be bad spark plug wires. Could be a distributor issue also. I had a terrible misfire in my B16 when I did my swap, it's on this forum somewhere. Ended up just having so much fuel it wouldn't fire. I let it evaporate and it worked out. Mine was literally pouring fuel out the tailpipe. I let it idle, moved the car a foot. Took a lighter to it and watched it burn.
Move the fuel injector to a different cylinder. See if the issue follows it.
Move the spark plug to a different cylinder. See if the issue follows it.
Move the spark plug wire to a different cylinder. See if the issue follows it.
Unplug the spark plug for the problem cylinder, while the car is running, you should hear the idle drop.
If it follows any one of the first three things, replace the part. If you don't get an idle drop with the fourth, you are definitely not firing on all 4 cylinders.
My guess is a faulty injector though.
Old Oct 8, 2013 | 09:07 AM
linkfan665's Avatar
Ok thanks guys I will check it all after work and let ya know
Primos EF
10
Apr 22, 2012 10:42 AM
mikede
May 17, 2006 05:35 AM
vtecn8ive
Sep 18, 2004 08:44 AM
honda_god
Apr 23, 2004 01:32 PM
xavierfg
Aug 23, 2003 08:58 PM
