93 accord clutch pedal return spring install
I removed the clutch pedal return spring so I could see how to remove the cotter key from the pin that connects master cylinder rod to the clutch pedal. After I replaced the clutch master cylinder, I cannot get the spring back in place. Can someone advise the proper technique on how to do this.
Chev
Aug 14, 2017 02:05 PM
