A mechanic saying, civic overheating needs engine overhaul?
Old Oct 7, 2013 | 01:07 PM
shm91's Avatar
Default A mechanic saying, civic overheating needs engine overhaul?
I was going to make sure where to mill the head before getting into the head gasket job. So, I went to this guy, and he goes that his son had a civic too, and he finally couldn't fix it and is going to sell it. My area has few machine shops by the way.
He said the civic engine block is rare type in that if overheated, the engine need swapped or overhauled to fix it EVERY SINGLE TIME. He said just changing the gasket and milling the head will only do two months, then it will leak again. He said if other mechanics tell me to change the gasket, to never do it.
I never heard of that. So, I called NAPA (one of the two machine shops in my area), he says it's 50/50 shot. I'd need straight edge on that.
I overheated the car three months ago (I noticed right away, because the ac blew warm air on a hot summer day), and I immediately pulled over, and towed it to my home.
Not vivid signs of milky residue, sweet smell, and oil in coolant yet, but very little. The coolant level in the reservoir fluctuates between top and bottom every time I drive though.
Any help could I get?
Old Oct 7, 2013 | 01:43 PM
ElectronBlue00's Avatar
Default Re: A mechanic saying, civic overheating needs engine overhaul?
For starters, what is the Model/Year/Engine in your car?
Old Oct 7, 2013 | 03:15 PM
fragmare's Avatar
Umm, sounds like the guy is full of ****. I changed my head gasket last summer, 47,000 miles ago, and I'm having ZERO problems with any head gasket leaks. Hell, I even got away with reusing the head bolts, which is a big no-no. Just do the correct gasket change procedure, use a good head gasket, and have the head resurfaced. Check the block surface for warpage too.
Old Oct 7, 2013 | 05:16 PM
fonkernuckle's Avatar
Get the head resurfaced at a minimum although now's a good time to get new valve seals and valves checked. New head gasket and some arp head studs
Never heard of such bs as what they told you.
Old Oct 7, 2013 | 05:53 PM
shm91's Avatar
What happens if block is warped, and how likely is the warpage if I shut down the engine right away?
Old Oct 7, 2013 | 05:55 PM
Dontoh's Avatar
It's not likely. If it's warped, it can be milled and there will be a headgasket that can compensate for it
Old Oct 7, 2013 | 05:57 PM
carlos8's Avatar
like fragmare said, Just do the correct gasket change procedure, use a good head gasket, and have the head resurfaced. Check the block surface for warpage too.
I've done several Honda heads in our shop with the right procedure and never had a problem.
Old Oct 7, 2013 | 06:31 PM
shm91's Avatar
Could the straight edge be replaced by a steel ruler at HomeDepot?
(http://www.homedepot.com/p/qv/100127627)
I heard I would need precision edge, which I can't afford. Or should I take the block to the machine shop, too? I have a feeler guage set by the way.
Old Oct 7, 2013 | 09:33 PM
fragmare's Avatar
Dude... don't worry about the block too much. It takes a MASSIVE amount of heat buildup to warp it. If you must check the block for deformation, just find a flat piece of glass (like from a coffee table or patio table), smear one side with a thin coating of clean engine oil and set it on the block, oily side down. Look for large bubbles or parts where the glass isn't touching the mating surface. That's a quick, accurate and inexpensive way to check for warping on any mating surface.
Just go grab the following items:
1) Fel-Pro Head gasket set from Autozone or wherever
2) OEM Honda head bolt set
3) An appointment at a *reputable* machine shop to drop off the head and have it measured and resurfaced, if necessary.
4) Some beer
Old Oct 7, 2013 | 09:55 PM
shm91's Avatar
Thanks dude.
1) & 2) OEM HG and Head bolts from dealer
3) For my relief, NAPA has head machine near my home
4) Yes
I guess for you (more experience than me - I just started fixing my car) to say MASSIVE, probably it doesn't apply to just five minutes of overheating.
Now, I pretty calmed down from worrying thanks to the comments that block at least doesn't have HIGH chance of warpage.
Thanks for the information people.
Old Oct 7, 2013 | 09:56 PM
shm91's Avatar
Was wondering reading through forums, if I need copper spray for OEM head gasket?
If it's better, what company do people use?
Old Oct 7, 2013 | 10:28 PM
fragmare's Avatar
For OEM head gaskets, a little copper spray isn't a bad thing since they are bare metal. Any brand would do, really. The main thing is to make sure both mating surfaces (head and block) are perfectly flat. The aftermarket head gaskets (like Fel-Pro, etc.) are usually pre-coated with a graphite coating, and also reinforced to protect against hot spots.
Old Oct 7, 2013 | 10:35 PM
doood's Avatar
been there done that
d series engines are so cheap and plentiful it would probably just be cheaper to swap in another one instead of rebuilding one back to oem specs. especially if you're not tearing it down and building it back up yourself.
Old Oct 7, 2013 | 10:43 PM
CO671's Avatar
If it's just the headgasket, here's what I wrote on another person's thread. If it's simply overheating and it's a Dseries motor then it's most likely just simple the headgasket blown, no need for full rebuild which sounds retarded. Honda's a motor company, and their motors are usually tough.
Anyway, here's what I told another guy:
* Machining the head is what I consider to be a must unless you can surely measure it and know it's perfectly flat. Don't adjust your valve lash until after you run the car, just so you know that the timing is still to spec, and you need to adjust the valves when the timing is mechanically correct. It only costed me $40 at my local machine shop to get it resurfaced.
* It's not necessary, I re-used mine when I did it, but if you're **** about it, get APR's. Just make sure you torque it all properly and put the headbolts back into the same slot where you removed them.
Here's what I wrote in a thread on ClubCivic:
When I first got my Civic 2 years ago as a 16 year old who didn't know much about cars, I threw out $3,000 and got it anyways.
1 week later, the headgasket and overheating started showing and I didn't have the cash or wanted to ask my parents so knowing nothing other than changing motor oil and coolant, I did research and in changed the headgasket myself.
I can't recall the overall price but you'll need essential tools:
Socket and wrench set (I got a $75 Craftsman set from Kmart)
Torque Wrench ($40)
Breaker Bar ($20)
Haynes Manual ($20)
Gasket set (headgasket, intake manifold gasket, exhaust manifold gasket) ~$100 around
Oil, filter, Coolant, etc; $100
Already had a jack and stands
Rough estimate of tools (that will always be used in other occasions) and parts: $400
Basically around $200 in parts
Align motor to TDC
Drained the oil, coolant, removed the manifolds off the head.
(put headbolts in certain order so you know which thread they came out of)
Using the correct cross pattern to remove the headbolts
Removed head, (set dowel pins aside with headbolts) cleaned it thoroughly, took it to a machine shop that leveled/resurfaced it for $40 overnight.
Rough estimate of labor: $40
Put everything back together re-using the headbolts in the correct order w/ torque wrench, (DONT FORGET THE DOWEL PINS)
Coolant, oil put in, fired it up.
I'm pretty sure that's all that was necessary I mentioned, apologies if there's any misinformation.
The shop costs alone are averaged $600-$900 for a headgasket change.
There are many Headgasket DIY tutorials on Honda-Tech, ClubCivic, all over the internet so Google would be a great companion, check them out.
These are resources I saved into my bookmarks
http://www.youtube.com/watch?feature...&v=YayYzTDV0uo
http://www.youtube.com/watch?v=TnShx...eature=related
http://www.clubcivic.com/board/showthread.php?t=206158
http://hondaswap.com/general-tech-ar...ts-pics-71528/
Old Oct 8, 2013 | 12:57 AM
shm91's Avatar
Those two vids are also in my bookmarks lol.
Old Oct 8, 2013 | 05:40 AM
JDM-Punk's Avatar
im curious, are you referring to the napa/fairfax auto parts in annandale? the guys at that machine shop have been there for a long time and def know their stuff (so i wouldnt worry about them not being reputable)
Old Oct 8, 2013 | 08:44 AM
shm91's Avatar
The first mechanic was Lee's auto on columbia pike, by the way.
Yeah dude, the fairfax auto at Merrified.
Glad for being assured that they know their stuff.
Old Oct 8, 2013 | 11:31 AM
nismoracingsx's Avatar
A NAPA here in florida just machined the head on my y8, great price and fast turnaround.
I asked the machine shop about copper spray and he said the best advice he had was to follow the service manual, if it didn't require it, to not worry about it
Old Oct 8, 2013 | 11:50 AM
zerovandez's Avatar
For my B18A, that has 175k miles now, I replaced the HG with Felpro from Autozone. I didn't mill anything. I used new "ebay" head bolts. A week later, I drove to Las Vegas in 100+ degree heat. Then after that, I drove it harder and faster. That all happened a month or so ago. And today, the engine is running just fine without any complaints or issues.
Old Oct 8, 2013 | 03:33 PM
fragmare's Avatar
Can I get an amen from the choir?!
Old Oct 8, 2013 | 05:50 PM
shm91's Avatar
Got ya. Honda manual is the best thing.
Old Oct 8, 2013 | 07:12 PM
94EG8's Avatar
Seagull Management
You're guy isn't totally out to lunch. I've seen a lot of blown headgaskets in D-series engines (D15B7 in particular) where the engine was just never right after a headgasket replacement. Generally from what I've seen they tend to last 6 months to a year. The D16Y7/D16Y8s have a higher success rate as do the the D15Z1 and D16Z6.
Old Oct 8, 2013 | 09:20 PM
fragmare's Avatar
I honestly think a lot of that has to do with taking the time to do the job right and using good replacement products. If you're just working at home, in your own garage, on your own car, you have a tendency to take more time and nitpick over small things... at least I know I do. In a shop environment, where things are more hectic and you might be under time constraints, things get overlooked and rushed sometimes. One of the biggest complications, after doing a head gasket job, imo, is failing to remove all the scraped off gasket material from in and around the cylinders. People think it will just "burn off" when they get the car running, but what they don't realize is that that stuff is tougher than they think. That semi-metallic graphite (or whatever it is) debris can stick around awhile. And while it won't really harm the cylinder walls or the pistons themselves, it can and will do a number on the softer piston rings. So the end result is someone does a hg change, fast forward 20,000 miles or so and they find they are burning more oil... why? because their piston rings are scored and allowing blow-by. Then they're facing a full engine tear down... which for your average DIYer is a pretty intimidating task.
Old Oct 8, 2013 | 09:39 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
x2 thats a good habit to have! Anytime I do a HG I clean everything and look over what I can i.e. cyl walls etc ..check the head with a straight edge and I always use a honda oem HG.. (if it is a simple build) and if its a high mile motor I will take and have it pressure check,tanked and cleaned . ... hope you figure it out best of luck!
Old Oct 9, 2013 | 03:40 AM
94EG8's Avatar
Seagull Management
For what it's worth btw I've seen a couple of guys put 5 headgaskets each in D15B7s.
