question about the weird noise from suspension/coilover
my car is 95 civic coupe, everything in that car is stock, however, everytime when the car turns, it will make some weird noise from suspension or top of the coilover, im thinking should be the bush on top of coilover getting old or crack, but i not really sure. Do u guys know about what this weird noise may be?
if is the bush on top of coilover getting old or crack, where i can find the bush and what is it call?
thanks
thanks
could be, do you have rubber between the spring and top mount?
Also, check your ball joints, when they start going bad, they can make noise too.
^ This!!! Mine sound a loud clunk when I take it out of the garage in reverse and turn the steering wheel full to one side. I not have the rubber between the coil over and top mount. But it only do it in this moment after this I can make U turns take bumps and no sound.
alphalanos
Sep 26, 2007 05:21 PM
