best place to get cam reground b series
lookin for the best mid range cam for my setup was looking to have my cam reground or buy a blox cam out of the 3 what one would be the best mid range power for my build
b17 regrind
in230°/12mm . ex227°/11.5
or
blox type c
in265°/12mm ex265°/11.5mm
or
blox type b
in 266°/12mm ex266°/11.8mm
my setup
b18c1 block
b18c1 crank
b18c1 rods
pr3 pistons .020 over
b16a head port matched and casting cleand up
blox valve springs
blox flat ex valves
blox intake
68mm intake
4to2to1 hedder
7lb flywheel
i should have a 11:1.1 compression and a 0.035in piston to deck hight this is going to be my DD so i need a stockish non vtec lobe
b17 regrind
or
blox type c
or
blox type b
my setup
b18c1 block
b18c1 crank
b18c1 rods
blox valve springs
blox flat ex valves
blox intake
68mm intake
4to2to1 hedder
7lb flywheel
type r cams are overrated just for the word type r i would rather spend 500 on a set of new cams i have had a few regrinds on chevy small blocks thay never gave me a problem
When u regrind a cam you reduce its base circle to gain lift which on a over head cam can be very destructive to the rocker arm assembly because of such aggresive ramping it can scrape the oil right off of the rocker pad a pushrod motor cam is not in direct contact with rockers I've had personal experience with regrinds on my b16 as well as seen many customers heads that have either wore out regrinds quickly or complete destruction of cam journals and rocker arms.. just try n to help you out that's all. But if want regrinds most of them are made by web cam who grinds a lot of other companies cams including bisi they would prob be your best bet. A billet or cast cam will be a better option though
you need to figure out exactly what you want to do. You have PM'd me about cams and stuff like 5 times now. Pic a set and stick to it. Honestly with your compression and build the Type R cams are not "hyped" up. They would do great. Otherwise something along the lines of a tuner 1 or 2 would be the best bang for the buck. I ran a set of the delta 282 regrinds in an old motor and they did well. That car was stolen before I had too many miles put on it though.
Just last week talked to a guy who has destroyed 2 rocker arm assemblys with a blox cam in a d16z6 I personally wouldn't run them. Most important no matter what your choice run a zinc additive the EPA has really screwed our oil up taking out key additives that protect the cams. Comp cams makes a good additive.
I run blox c cams and Ihave a few friends that have over 2 years with there blox cams and never had a problem. I'm sure this has been covered in HT so many times. You can get everybodies op, but I think its how hard you push any product and what you want it for. Now I have about 6,000 miles on my build and I have not had a problem with my blox type c's yet, lol but you never know.
You didn't bug me I'm just saying you need to narrow down your options. The crower 402's would work decent that you asked me about. The blox c's are essentially jun 3's which are a great cam as well. The tuner 2's perform well in just about every motor I have seen a dyno on. The BC and Skunks will be much higher quality and the companies will stand behind their products much better.
Typically, you can fit 10 degrees more duration and about 0.7 to 1.0mm more lift without making the base circle too small, which affects how many teeth the locknut will engage on the valve tappet.
Also affected by the smaller base circle is where the cam lobe contacts the rocker pad. On BVTEC, the rocker ratio (RR) is reduced, reducing "cam action." On LS the RR is increased, with the decreased base circle, making it a lil spicier from the increased RR alone.
could you explain why you say itr cams are overrated? my ctr cams helped me do this in this vid! nice bottom end tq and good midrange.
Video Link: http://m.youtube.com/watch?v=arifuqtoXmA
[QUOTE=vtecmasta85;49201559]could you explain why you say itr cams are overrated? my ctr cams helped me do this in this vid! nice bottom end tq and good midrange.
That is a nice pull sir.
