Issue with cruise control pulsing??
I added cruise control into my 88 hatch using all oem parts, both junk yard and from my old 90 sedan. i wired it up using the wiring diagram from my helms manual, it DOES work, but is there a way to adjust it and or stabilize it?
I ask because it doesn't just hold the pedal steady, it pulses it, getting on the gas the getting off, which may not be an issue if i were stock, but being boosted it gets annoying since the speed up effects are more rapid.
again all parts are oem, but i have converted my car to an electronic vss from a 96-00 civic but i don't have any codes or issues with my speedometer, and i'm using the proper gear for my dif.
Had this problem with my wife's 90EX, I found the cable from the actuator to the throttle to be loose. Not too sure if it fixed the problem as I didn't use cruise much. It's a quick check so it's worth a shot.
I had a similar issue, though mine did not go to the gas pedal. I found the speedo bouncing too, so I greased up the cable and problem fixed. I'm guessing your VSS might be to blame.
i have a spare i can switch out, which i'll try, but the pulsing is mechanical, i can feel the gas pedal move, watch my car go in and out of vacuum on my boost gauge, and see my afr's changing as well.
honda.lioness
Oct 12, 2008 12:03 AM
stackz
Jan 17, 2007 03:31 PM
Jonathan_ED3
Mar 28, 2006 07:38 PM
