WTT 1992 civic sedan (EG8) 5spd for Honda Ruckus (IL)
Old Oct 5, 2013 | 09:07 AM
94IntegraRS's Avatar
Default WTT 1992 civic sedan (EG8) 5spd for Honda Ruckus (IL)
Contact: 217-717-5529
Hello, I am looking to trade my 1992 Honda Civic sedan for a Honda Ruckus (50cc-150cc) or a delsol
The civic has a D15B7 with 5 spd tranny. It has 165,242 miles. (Its a project car and DOES RUN & DRIVE)
Ill start off by indicating the bad about it:
previous owner I believe had plans on auto xing the vehicle so all rear interior has been removed, I have a spare rear seat out of a ej coupe and installed it,but it is a little to short on each side. Also it has the typical honda rust on both rear quarters,but its a little rough,but can be fixed . It doesnt have a the adapter piece for the radio, but you can go to the junk yard and take that out of any civic to replace. No a/c or power steering. The last bad thing about it is that the driver side inner door opener is broken so you have to roll down the window to open door while inside.
Now for the goods:
- It has an Spectre short ram intake system
- no name cat back exhaust system
- no name header
- no name adjustable cam gear
- Front end has been lowered 3 1/2 on no name coil over sleeves, while the rear is stock?
- Aftermarket ichibahn steering wheel
- Integra swapped center console, just missing shift boot
- has all 4 door visors, and rear window visor
- I have a d16Y8 head for it, but it need head bolts. I had plan on doing a mini me build. Also it has a new vtec solenoid.
- I also have a disc brake conversion for it, but only things missing for the conversion are caliper and brake pads (90 crx si)
- If its to my liking I will put on my black set of LS meshies
- Clean and clear title in hand!
- NGK spark plugs, and spark plug wires
- New valve cover gasket w/spark plug garments
- I can also give a dual 12 inch sub in box with a dual 400 watt amp
Old Oct 5, 2013 | 10:57 AM
jrp355's Avatar
Default Re: WTT 1992 civic sedan (EG8) 5spd for Honda Ruckus (IL)
looks kinda like my old four door
Old Oct 5, 2013 | 07:13 PM
rayvo's Avatar
how much to buy?
Old Oct 7, 2013 | 08:14 AM
Originally Posted by rayvo
how much to buy?
prolly $1500 obo
Old Oct 7, 2013 | 12:22 PM
Jakester9500's Avatar
http://hondamarketplace.com/showthread.php?t=3171616
Couple posts down from you, guy looking to trade a Ruck for a winter beater.
Old Oct 9, 2013 | 07:31 PM
Ya I posted on it,but he isnt responding =(. Also he mentioned he wants something with cruise control which my car doesnt have, but thanks for the reply.
Old Oct 12, 2013 | 10:04 PM
Bump
Old Oct 19, 2013 | 07:24 PM
Bump (updated pics to come soon)
Slowass4dr
Jan 30, 2006 06:23 PM
