Transmission & Drivetrain Gearboxes, Differentials, Clutches
Spec Twin disc in backwards?
Old Oct 5, 2013 | 07:50 AM
92hondalude's Avatar
Default Spec Twin disc in backwards?
Hey I was hoping someone on here would be fimiliar with the spec mini twin clutches. Long story short I blew my quaife diff so I pulled the transmission out installed a mfactory diff with new bearings and shim and all that mess. When I ha the transmission off I noticed that the rear main seal was leaking so I decided to pull the clutch off and change that. Now that I have it all back together the car will not go into any gear while the car is on (like the clutch isn't disengageing). But when the car is off I can go into all the gears. Does anyone know which way the disc against the flywheel goes. The other disc has a sticker to its obvious that one is correct.
Thank you in advance for your help
Navy_Kyle
Jul 9, 2013 10:42 PM
kd97accord
Nov 29, 2010 09:25 AM
standbackimapro
Dec 25, 2006 04:26 PM
93FastLs
Sep 1, 2005 07:28 PM
