Fuel issue
Hello i have a problem i cant seem to resolve on my own.
Okay so my caris a 1994 si, d15b,z6.
I put in $25 for gas two days ago and now the car wont start due to no gas.
I have a aftermarket fuel pressure regulator with a meter that reads 4 .
The car also came with a greddy emanage blue. I tried disconnecting this from the ecu to see if it will do anything and when i tried starting the car it sounded horrible . It sounded like it was popping and about to blow. The wires from this emanage is tapped into the ecu wires. Should i remove this and clean up my ecu wires? And get it tuned after?
What can cause a gas leak? Where are the fuel lines so I can check them?
Also i was told it could be injectors as well ill check those when i have fuel again.
Any help is appreciated.
