tach install
Where do I connect the wire for the rpms when installing a autometer monster tach? I don't have the original instructions, and would prefer not to mess anything up.
if its for a honda/acura there is a blue wire on the driver side engine bay by the firewall that has a rubber peice at the end splice it to that, it should work.
Or if you want you can pull out the instrument cluster and on the left side, behind the factory tach, is a blue connector and that has a blue wire in it. Tap that wire and your set.
danielfleenor
Nov 26, 2009 02:29 PM
Tyson
40
Jun 4, 2009 04:24 PM
90crxdriver
10
Nov 4, 2006 12:14 PM
