1998 Honda Civic w/GSR swap
1998 Honda Civic DX coupe
B18C1 with B16 em1 trans with quaife lsd with CTR final drive
142600 miles on the body
1000 miles on the engine
NEW:
Hasport street engine mounts
skunk2 proseries intake manifold
skunk2 alpha 70mm throttle body
205/50/15 kumho Ecsta's on spray painted konig GTR's
ARP headstuds
OEM oil pump
OEM water pump
Exedy OEM clutch
OEM piston rings
ACL race rod and main bearings
eBay distributor
Rywire ecu OBD2a to OBD1 harness
Rywire vtec subharness
Front seat belts warrantied and replaced
Timing belt, Tensioner and all gaskets replaced
Mods:
1995 Integra SE front knuckles, rotors and calipers
1995 Integra SE rear trailing arms, rotors and calipers
Integra Pacesetter catback exhaust system. sounds great but does not fit exactly like i wanted it to
skunk2 drop springs with badly blown struts
blox rear lcas
DC sports exhaust manifold
head was resurfaced and .005 was taken off as well as the block decked
EPROM p28 ecu
not really a mod but i flushed the entire brake fluid system with DOT4 fluid
NOTE: has very small amount of rust around rear passenger wheel well!
ive had this car for 5 years and it has been nothing short of reliable for me. the last year i decided to make it a project and swapped the engine. in the last month and a half, the car has been sitting around and i have just lost the interest to work on it. its a blast to drive and pulls very well. i assembled the engine myself(i am an ASE certified Honda technician). all machine work was done by Automotive Machine in Fraser. to be daily driven it needs new struts, a new radiator(does not over heat whatsoever, has small leak due to incorrect outlet size) and a depending on your preference a power steering pump. i would not hesitate to jump in this thing and drive to chicago the way it sits. I'm going to start the price out mildly steep but i have way more invested into it and i would just like to get SOMETHING back.
586-808-4126
Car is located in Macomb twp michigan
asking price: $4500. NO TRADES! looking for cash only!
Apparently pictures can't be upload via mobile version so please text me for pictures!!
NEW:
ARP headstuds
OEM oil pump
OEM water pump
Exedy OEM clutch
OEM piston rings
eBay distributor
Mods:
blox rear lcas
EPROM p28 ecu
586-808-4126
r1de23
Jun 30, 2009 07:35 PM
