help!!! 2000 honda civic d16y7 tranny blinking d4!
ok so i bought this car did timing water pump and tensioner. then i slipped the belt by high rpm then it bent all the valves interference motor so i had my mechanic replace all valves shave head new head gasket she is back up in running. when i first got the car tranny had no oil. i also removed the engine before valve job then put engine back. she will go into R&N&D2&D3 will not shift D4 it says it is stuck in 4th but i can put it into D2&3. i took top siloind off tested it it is working. cleaned it put it back still blinking light D4 i think that when i bought it and it had no tranny fluid is the cause. any help on getting it to shift again would be greatly appricated. when i first got the car it shifted fine. i think i might of cause power serge or something or my tranny is just bad. i can still drive the car take off in D2& pop into D3 runs and drives i just dont know why now it wont work also yesterday in the middle of no where the brakes started giving out. also i ran a/c at the light and engine stalled out. when it idles it idles kinda high. i need advise o n figuring out if i can fix the tranny or do i need a different one. i really want to sell this car!!!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Start there. Pull the code. Post it.
I had two major codes tranny malfunction and clutch is locked. it is automatic those are the main ones that showed up there was five codes total
turbo tm
Acura TL, RL & ZDX
Nov 28, 2005 09:26 PM
southphillyman
May 29, 2004 10:24 AM
