CTR Springs and Shocks
From this picture, can anyone tell if these are authentic CTR Springs and Shocks? A friend of mine is thinking about buying them but he's not sure if they're real. Any consideration given to this matter will be greatly appreciated. Thanks
why does your friend want a stock/oem shock/springs. For the same price or less he can get a good set of aftermarket springs and shocks. I don't think there's a difference in jdm and usdm spring/shocks.
The ctr comes with adj. height spring/shock stock from factory? that's nice
I'm gonna say no - at least for the rears. JDM rear LCA's are different than USDM. Here is what the rear shocks should look like:
So then what kind of lowering would you get if you put that CTR combo (springs and shocks) on a Civic Si?
Probably not much. The CTR is a little lighter, so the heavier Si will sit a little lower. But you would be loosing suspension travel as well. Might as well buy some good aftermarket shocks which btw, check my sig.
B16X
Jun 25, 2005 11:53 AM
