Bored post 90 si rebuild.
Old Oct 4, 2013 | 11:12 AM
suburban_ninja's Avatar
Default 1990 Crx Si Rebuild
So here it is. Long overdew on getting another crx here is what I been through so far.
That's as she was picked up. With 88 wheels and 88 bumper.
Found a 90 bumper and did the lame dlaa lamp install. Along with amber lamps.
Installed.
Primed.
Masked and painted.
Donor engine. D16Z6
Prepped painted and sanded lettering valve cover.
Si's that I'm working on polishing. This is how I got them.
Now I sanded polished masked off spokes re silvered the inserts.
Still have 3 left to do.
Dirty head.
All cleaned up ready for machine shop.
Engine as it sat.
Pulled out.
Right now I'm waiting on machine work for both the head and the block before anything can continue. Thanks and will try to keep updating if I don't get to lazy.
Old Oct 4, 2013 | 11:17 AM
Mister Clean's Avatar
Default Re: Bored post 90 si rebuild.
Great progress! Where did you end up getting the Rio Red paint for the bumper? Custom aerosol order online?
Old Oct 4, 2013 | 11:27 AM
It's actual automotive paint base and clear shot from a sata hvlp gun. Got the paint from local paint shop. All high quality stuff still shot in a driveway haha. Didn't turn out to bad. Need to wet sand and buff out some trash from the clear but overall came out nice. Probably we be painting a panel here and there where I find time to.
Old Oct 7, 2013 | 05:59 PM
Update:
Got some goodies in. Supertech valves, guides, springs, and stem seals. Rywire obd0 to obd1 with vtec and distributor conversions. Golden eagle adjustable cam gear. And last but not least bisimoto lvl 2 camshaft. Updates to come.
Old Oct 7, 2013 | 07:14 PM
JDp0wer's Avatar
Nice start.
Old Oct 11, 2013 | 10:27 AM
Alright newest update. Got the head back all cleaned up and install all new supertech valve train. Getting closer but still so much work to be done.
Old Oct 11, 2013 | 10:32 AM
Freemananana's Avatar
Love the wheels. Good luck with the motor overhall.
Old Oct 11, 2013 | 10:54 AM
Thanks man. I need tires bad. Whoever had them before me had some huge tires on them lol. Would like a little lower profiles plus they are bald as ****.
Old Oct 11, 2013 | 11:18 AM
Tire Rack is a really good site. Keep your eye open for the size of wheel you want and they have sales every now and again. I know my rims aren't OEM honda or anything baller, but I got my rims and Fuzion ZRi low profile tires shipped to my door for just over $400. Tires were like $40 a piece.
Old Oct 11, 2013 | 11:59 AM
Yea I'm in the automotive industry so I have some tire connects it's just finding some spare change to drop on them because I'm funding the rest of this build trying to get it running. My factory crx wheels have excellent tires on them so I'm not in a rush plus I have 3 more wheels to polish so I'm not ready to mount them anyways. In due time I suppose.
Old Oct 11, 2013 | 02:27 PM
Pretty much my plan. I use my rims most of the time, but I still have my stock 13'' steelies with really nice tires. I beat on them sometimes.
Old Oct 16, 2013 | 06:57 PM
About to pick up my freshly cut and overbored block tomorrow. Just need new mains and rod bearings and head studs and that much closer to being put back in. Pics to come tomorrow.
Old Oct 17, 2013 | 03:05 PM
Well quick update more pics to come. Got my block back. With fresh machine new pistons over bored .50mm with crank fresh polished.
Old Oct 17, 2013 | 03:41 PM
How much did you spend on this motor so far? Looks clean.
Old Oct 17, 2013 | 05:53 PM
To much. Haha I don't care how much it cost I love clean crx's. Hell clean Hondas in general. Between the engine it's self from the scrap yard about $180. Then all the machine work $280. And all the goodies close to $1000 in cam gear, cam, valvetrain. Another $400 or so in wire conversion harnesses and ecu and other odds and ends. So I'm close to 2k I guess. May sound crazy but engine wise should be a 0 mile car on a pretty solid chassis. Will try to get some more pics this weekend of the car in general. I'm so ready to get this thing running.
Old Oct 17, 2013 | 05:59 PM
Oh and by the way before I get bashed and why not just B swap it man for the money you have in it. Trust me I know and wish I could but I would have went through the same entire process I did with this engine because I wanted it completely rebuilt from top to bottom. It would have been a $1600 engine plus a $2000 rebuild. So I know there will be some haters but I like to take pride in this car and want it done as correctly as possible.
Old Oct 18, 2013 | 04:01 AM
Nah, do what you want. I can't hate on someone's choice to make a clean car. I spent $1000 on my swap. It looks pretty clean though. 60K miles or so. It's not a 0 mile motor like this. This motor will last a life time if you take care of it.
Got a question for you, any tips on cleaning the engine bay with the motor already in? Mine is grimey and I want to clean it up this weekend.
Old Oct 18, 2013 | 05:07 AM
Well I did mine with it out. But I would recommend simple green. Buy the concentrated gallon. It has mix strengths on the side of ratios to use. Put it in a spray bottle and cover the electrical components. I.e. Distributor, main relays, other stuff like that with ziplocks or grocery bags. Then spray the solution around the bay let it soak a bit then hose it down. Repeat till clean. Then take a rag and spray the solution on the rag. Hand wipe down the electrical components you covered. I'll post pics probably tomorrow of how well it cleaned up my pitch black tranny and my bay.
Old Oct 18, 2013 | 07:58 AM
Nice. Simple green. I have industrial degreaser. I believe I can get my hands on some simple green though. I'll give it a shot. It's hard to scrub in there, so I was looking towards something I can spray, soak, and spray off.
Old Oct 18, 2013 | 09:19 AM
Pressure washer would work best but be super careful on what and how you spray. Real easy to damage stuff with a pressure washer or possibly even hydro lock a motor if you shot it down the intake or spark plug wells. So if your not happy with rinsing. Pressure wash works good.
Old Oct 18, 2013 | 09:56 AM
Rinsing is easy. I just can't shove my hand in some places to use degreaser and a sponge. That was my original plan. Thanks for the advice though. I don't have a pressure washer, so I'll do a couple cylces of spraying and rinsing.
Old Oct 28, 2013 | 02:02 AM
Well got a lot done this weekend sorry I did not take more pics it was hard to but I did get a few of the assy of the engine. Getting close to install still need more parts but it's coming along.
Old Oct 28, 2013 | 02:56 AM
Why is there an accelerator cable just creeping its way into this photo? But seriously, the motor looks fresh. Like just walked out of the 90s. Also, that VTEC solenoid is weird! I never noticed where they were on SOHC. Mine is right by the Distributor and it has become 'normal' to me.
Old Oct 28, 2013 | 03:51 AM
Haha yea that cable is off the donor engine. Just haven't took it off yet. My throttle cable I'm using is still in the cars chassis. Still have a lot of wiring hosing and sensor type stuff to do on it so pay no attention to hoses or electrical lol. I wish the guy that did my block cleaned it better but oh well. And I need funds for a header I don't want that ugly stock thing haha I painted over the rust and tossed it on for now till I can afford a legit header.
Old Oct 29, 2013 | 04:19 AM
So I have a ton of sensors in on the way. Different timing belt. Going to run the gates racing belt since I'm running open timing covers. Ngk wire set and more goodies on the way. Pics to come.
