Everything Brand New !!! Built Head, Built Block, Drivetrain, Mounts, Fuel setup.
Might be moving out of state. I DO NOT have to sell but after the motor was built it has just been sitting on the stand for a couple of months now and tired of looking at it especially after nothing the but the best parts were used. If its not sold I have no problem keeping it and putting it to use for next years events.
Everything is BRAND NEW with 0 miles unless otherwise noted.
Most internal major components were purchased from Real St. performance ouf of south FL
(ex: Cams, gears, pistons, rods)
Pricing is listed, like everything in life price is negotiable within reason.
I will set a price for the whole longblock of $4000 from manifold to oil pan.
I'm sure I'm missing some details so if you have any questions please do not hesitate to ask.
If you have anything neg to say please click the x at the top right of your screen thx.
Here's the list.
*00 Si B16 Head (all head work done by slowmotion motorsports out of ohio)
-Supertech valvesprings
-Supertech Ti retainers
-Supertech dish valves
-Fresh resurface
-Ported intake side
-Ported and Polished exhaust side
-3 angle valve job
-New exhaust guides
-GSC (power division) Stage 2 camshafts
-Skunk 2 vtec soilenoid
-Skunk 2 solenoid cap
-Brian Crower cam gears
-Edelbrock Victor X manifold
-70mm TB
-Mildly polished Distributor
-Extened intake manifold studs
-Speedfactory thermal intake manifold gasket
-USDM ITR valve cover
-Kevlar spark plug cover
*01 B18c GsR Block (Assembled by Certified Racing out of NJ)
-82mm Wiseco 10:3:1 forged pistons
-Manley Rods
-3 layer JE headgasket
-Micropolished and balanced crankshaft
-Beadblasted
-Fresh deck and hone
-ACL bearings
-Moroso oil pan
-ITR oil pump
-Gates racing water pump
-Gates racing timing belt tensioner
-Arp Head studs
-Arp rod bolts
-IPG pvc block and breathing fitting kit
Here's the list.
-Fresh resurface
-Ported intake side
-3 angle valve job
-New exhaust guides
-70mm TB
-Manley Rods
-Beadblasted
-ACL bearings
-Moroso oil pan
-ITR oil pump
-Arp Head studs
-Arp rod bolts
Parts will only be sold as a package, meaning the whole fuel setup not just two things, sorry for the misunderstanding. As of right now only the long block is up for sale, If its sold then the misc parts will be parted out or sold to the buyer of the long block.
andyman97
Oct 27, 2015 10:22 AM
NUISANCE
25
Nov 8, 2013 10:57 AM
Death_to_Thieves
Apr 27, 2009 10:19 AM
