Transmission & Drivetrain Gearboxes, Differentials, Clutches
When do axles start breaking?
Old Oct 3, 2013 | 08:14 AM
integrainside's Avatar
Default When do axles start breaking?
On a B-series setup with OEM axles, at what power range do you start to see significant breakage? I don’t mean an axle breaks once a year, I mean where it gets to the point that you have to look into drive shaft shop axles because you are breaking OEM every time you go to the track.
Also when those axles fail, where do you most often find the failure point on the axle?
Just wanted to take a sort of survey to see what everyone’s experiences were. With that, please only offer what you actual experiences were, not looking for guesswork.
Old Oct 3, 2013 | 03:03 PM
bks84's Avatar
Loved
Default Re: When do axles start breaking?
200 whp and 24" slicks
on mine it was the splinned part that slid into the intermediate shaft.
Old Oct 3, 2013 | 05:44 PM
Did you replace those axles with a stronger aftermarket axle, like a Drive Shaft Shop axle?
If so, did you run into any transmission failure issues when you upgraded to a stronger axle?
Old Oct 3, 2013 | 06:21 PM
bks84's Avatar
Loved
no i did not. i just went to smaller tire and hooked and didnt break anything
Old Oct 3, 2013 | 09:35 PM
TravisBiggie's Avatar
simple google search would answer your question..
I believe there are two kinds of axles available in b series motors/drive trains.
I know stock axles can handle 500whp+
3 seconds, I found this thread....
https://honda-tech.com/forums/drag-racing-36/how-much-hp-can-stock-axles-handle-2288606/
Old Oct 4, 2013 | 05:40 AM
kyden's Avatar
how much power does the car make? usually it's 26" slicks that kill transmissions. I am at 480whp on stock axles. haven't broken one yet.
brians356
24
Oct 16, 2015 12:55 AM
srok1
Sep 15, 2009 04:01 PM
keepitngga1
Dec 21, 2006 05:00 PM
type Gendy
Jan 19, 2003 06:18 PM
John
May 13, 2002 10:56 AM
