No Brake lights, horn, rear turn signal (driver's side), or cruise control
Old Oct 2, 2013 | 07:36 PM
adnoh97civic's Avatar
Icon3 No Brake lights, horn, rear turn signal (driver's side), or cruise control
Hi guys,
I've got a 97 civic ex sedan and my problem is that the driver's side rear turn signal, brake lights, horn, and cruise control do not work at all. The driver's side front turn signal blinks fast and the passenger's side front and back turn signals work fine with normal blinking. I've checked the number 12 fuse under the dash, i've checked each and every bulb (switching them around and all four bulbs work fine). I am completely lost at this point and i need some help. I've done some researching on the Combination switch, my combination switch seems to work just fine. Also whenever I press the Hazard Light button, all of the lights work (front and rear passenger's side and front driver's side) except the driver's side rear. For the Brake light I've checked the fuse, and I've taken out the Brake light switch and tested it for continuity. It seems to be working fine. Also my parking lights work fine, but they do not get any brighter once i hit the brakes. ... Any ideas anyone??
Old Oct 2, 2013 | 09:57 PM
crazyhouse2011's Avatar
Default Re: No Brake lights, horn, rear turn signal (driver's side), or cruise control
I advise against driving on public roads until you get this problem fixed. The berries wont hesitate to pull you over and ticket you for that.
dlwinger
Honda CR-V & Element
Jan 18, 2017 06:57 PM
kevint1030
Honda Civic (2001 - 2005)
Nov 3, 2016 06:29 AM
sd619jef9
Apr 12, 2011 04:57 PM
im done
Nov 12, 2004 08:52 PM
jdmaccordh22
Mar 18, 2003 06:07 PM
