Code 3 and Code 5
Old Oct 2, 2013 | 05:50 PM
BigbamaBen's Avatar
Default Code 3 and Code 5
I have an 88 crx so with a full 91 si harness and the Harness custom built by one of our members for the dohc zc. I'm trowing a code 3 and 5. Both are for the map sensor. 1 for the vacuum and 1 for the sensor on a pm6 ecu. My question is can 1 trigger the other or am.I just screwed?
Old Oct 3, 2013 | 02:36 AM
Freemananana's Avatar
Default Re: Code 3 and Code 5
Check the wiring at the MAP sensor. Make sure it's plugged in. You may just have a bad MAP sensor, which should be an easy replacement. Shoot, I bought a GM 3 Bar MAP sensor for $20. Should be able to find a stocker for that price.
Old Oct 3, 2013 | 04:43 PM
BigbamaBen's Avatar
Price isn't the issue. Me needing it by tomorrow is. already checked craigslist
Old Oct 4, 2013 | 02:45 AM
eBay my man. If I didn't need mine I'd mail it to you overnight just to see if it was actually the problem.
Rush jobs are the hardest.
tek9_ej2
Apr 10, 2010 05:13 AM
FSS13foxtrot
Jan 20, 2008 06:23 AM
chrysler kid
Sep 28, 2004 07:24 PM
1BadCvC
Sep 13, 2003 07:01 AM
