Accord 2002 Window Stuck - No Power
Old Oct 2, 2013 | 03:50 PM
Broken Thumbs's Avatar
Default Accord 2002 Window Stuck - No Power
I have a 2002 Accord and the rear driver side window does not work.
Electricity is not getting to the motor for some reason.
The window was originally stuck down, using direct power from the battery rolled it up (thanks to a neighbor who had that tool). Namely, the motor and regulator are fine.
I checked the fuses and they were fine.
I tried swapping the window switch on the door and it didn't do any good.
I tried swapping out the master switch panel on the drivers door and nothing.
The motor is not getting power. The door light is lit though, so some power is getting to the door.
All other windows work just fine (not sure if that indicates anything, if they are daisy chained)
How can I test from here? What else could be causing the issue?
Thank you in advance for your help.
Old Oct 2, 2013 | 04:19 PM
professorman's Avatar
Default Re: Accord 2002 Window Stuck - No Power
Check this wiring diagram and trace backward testing power with a voltmeter.
Old Oct 2, 2013 | 04:30 PM
Thanks professorman!
I'll take a look and see what I can figure out.
stoney0264
Jul 6, 2011 02:52 PM
tormont
Dec 1, 2010 08:44 PM
Cletus2k
Sep 9, 2009 08:08 AM
diyFool
Oct 13, 2008 06:29 PM
mickyandmickey
May 12, 2008 05:13 AM
