headlight problems
Old Oct 26, 2002 | 02:52 PM
98civicR's Avatar
Default headlight problems
I took a headlight off a 98 civic at the junkyard. I took it apart to see if I could take the yellow markers out of it. Now the problem I am having is the sealant on the headlight. It's really hard to get off. Any body tell what I can use to get it off.
Old Oct 26, 2002 | 02:57 PM
ebpimpin's Avatar
Default Re: headlight problems (98civicR)
stick the headlight in the oven for a little while to heat up the sealant. the sealant will become soft and you will be able to pull the headlight assembly apart. just remember not to leave the headlight in the oven for too long. an alternative is to use a heat gun.
Old Oct 26, 2002 | 02:58 PM
99DXcoupe's Avatar
Default Re: headlight problems (ebpimpin)
yeah that would a good one in the oven or use a hair blower or a heat gun
Old Oct 26, 2002 | 03:06 PM
98civicR's Avatar
Default Re: headlight problems (SI-racer)
no I got the headlight apart. I want to know is the something I should use to get the sealant off the headlight. Should I just stick it in the oven again and peel it off?
Old Oct 26, 2002 | 11:08 PM
dwnthehatch's Avatar
Yes
Old Oct 27, 2002 | 01:28 AM
EddieHatchBlack's Avatar
also try goo gone or goo off or something like that.
Old Oct 27, 2002 | 05:53 AM
98civicR's Avatar
Default Re: headlight problems (Eddie HatchBlack)
thanks I'll try it today and get back to ya
Old Oct 27, 2002 | 01:12 PM
sprcvc96's Avatar
Yeah, please post how this turned out. I am painting the housing and ran into the same problem when I had them taken apart. Thanks.
Old Oct 27, 2002 | 06:38 PM
98civicR's Avatar
Default Re: headlight problems (sprcvc96)
Hey well I tried heating it up but that was pretty much impossible to get it off. I'm going to take it to work tomorrow and see if the mec. can figure out how to do.. Anybody got anyother tips I need help bad.
Old Oct 28, 2002 | 03:30 PM
98civicR's Avatar
still no luck anybody done this before??
Old Oct 28, 2002 | 03:31 PM
ejprimo's Avatar
heat gun works wonders.
Old Oct 28, 2002 | 03:36 PM
black2kcivic's Avatar
Default Re: headlight problems (ejprimo)
heat gun worked for me, just try not to get it too hot.
Old Nov 4, 2002 | 06:10 PM
98civicR's Avatar
Default Re: headlight problems (black2kcivic)
did you get all of the sealant off or did you leave some of it in there. Do you headlights leak at all?
DieMaster
Paint and Body
Feb 26, 2016 01:52 PM
aaronfunstuff
14
Feb 24, 2014 02:27 PM
HaRrYbOy
Honda Motorcycles
Jan 2, 2006 09:45 PM
94ls
Jan 28, 2005 07:30 AM
