Just got a B17A swap!
damn i should of takin my friends b17 when he salvaged his 93 integra for 800 bucks
how does it feel compared to the b16 same thing im guessing or not a difference at all
[Modified by lamchop0000, 6:40 PM 10/26/2002]
If you are using the 93 GSR obd1 injectors, you dont need a resistor box.
You should replace the water pump too, and you'll need the obd0>obd1 jumer harness.
I am using the stock 91 civic si air intake assembly in my crvtec, works fine for now.
The wiring harness should be attached to the motor with all the plugs and stuff, an no you will not need the fuse box.
AAHHHHHHHHHHH YEA!!!
why would you switch to obd1? i dont understand why people do this? i have not heard of any advantage, if there is please tell me.
HCP. is real stiff. I
my HASports. For header the RS*R is nice, Intake, 99-00 Si CAI will work or you can make your own. Even the intake you have now should work. I might have my stock header up for sale soon. If you interested
92-93 gsr. these motors are hard to come by these days. they are even more rare then a type r from what i hear.
It took me about 5 months to find and aquire mine, 93 tranny that is.
from what I understand the GSR is the same as the YS-1 from the cable b16.
B-Gears
Quoted from ff-squad about the 92-93 GSR tranny, "Same gearing as 92-01 hydro SiR/ITR/CTR but in cable form. Optional LSD."
The 1992-1993 JDM XSi is a B16A. But the 1992-1993 USDM GSR is a B17A. This is one of the few instances where the US market was offered the better motor.
[Modified by StorminMatt, 5:33 AM 10/31/2002]
There were only 4000 (2500 92's 1500 93's) 92-93 GSR's made making them much rarer than a Type R. The B17 was also a limited production motor with much better build quality than other B-series motors.
My stock 150k mile 92 GSR with only a AEM intake for a mod ran a 14.9 1/4 on stock street tires. That was in a 2500 lb car so in a CRX it would fly.
, OBD1 ECU's don't require a resistor box.
