95 Accord swap f20b problem with wire harness
Old Oct 2, 2013 | 07:22 AM
AllAboutHonda's Avatar
Default 95 Accord swap f20b problem with wire harness
Okay, guys my brother just bought a 95 accord with a f20b and I notices that some of the wires are not connect it. I'm not sure if it need to be connect it or not needed. I'm not sure what kind of harness that is, It could be the 95 accord harness that I'm not sure of. Any kind of help would be appreciate.
These are the things that are not connected: water temp switch, EGR, intake air, and theirs this switch under the oil filter that is not plug. I'm not sure if that's the knock senior or what's that is but it is not connected as well and is there anyway I can pin point which harness goes where?
Thanks guys for taking the time to read this,
Old Oct 2, 2013 | 07:51 AM
Apex1972's Avatar
Default Re: 95 Accord swap f20b problem with wire harness
since you notices that some of the wires nots hooked up you should hooks them up. yo!
Old Oct 2, 2013 | 09:21 AM
Sispeed6's Avatar
Call these guys they will be able to help you 571-379-7448... Phillip... www.japaneseengineimport.com. these guys are located in N. Va.
Old Oct 2, 2013 | 04:04 PM
nus_dogg's Avatar
It all depends on what ECU he's running. If its a P28 chipped or whatever, he can bypass the EGR, IABs, and Knock sensor and wouldn't need to hook them up.
2ndchirp
Feb 7, 2009 08:30 PM
omarisramo
Jul 3, 2008 05:17 AM
aasaa666
Mar 6, 2008 09:26 PM
xtrmspeed
Sep 5, 2003 09:26 PM
