b18b1 starting issue
Old Sep 30, 2013 | 10:18 AM
91 b20 integra's Avatar
Default b18b1 starting issue
only happens under standard operating temp.imagine driving to the store for a 6-pack. takes a few min to get in and get out of the store. car is still warm, started fine, drove my *** up there just fine, but is now giving me trouble trying to restart. let the car cool down, starts fine.
what components change under temp? idles fine
Old Sep 30, 2013 | 10:22 AM
Default Re: b18b1 starting issue
car is a 98 integra for what its worth
Old Sep 30, 2013 | 10:28 AM
kyden's Avatar
check main relay.
Old Sep 30, 2013 | 10:39 AM
what am i checking? is there an obvious sign if this is in fact the culprit?
Old Sep 30, 2013 | 11:43 AM
did some research. thanks man
Old Oct 7, 2013 | 08:27 AM
now i have a cylinder 2 misfire. car has poor throttle response, loss of power, and 150k miles. anyone have an idea? replaced the main relay, problem of not starting after reaching temp continues...in addition to the trouble code
Old Oct 7, 2013 | 06:11 PM
Eg.ls.turbo's Avatar
Plug wire probably went bad or ur spark plug is bad, or need new distributor cap... Basically a tune up. How long has been since u did tune up?
Old Oct 9, 2013 | 04:00 PM
weeks lol, brand new everything. i cant think of a component that would cause a misfire since ive done the major components. ill check for a fouled plug, anything else?
Old Oct 10, 2013 | 06:30 AM
fcm's Avatar
fcm
Old Fart
Bad plug or bad fuel injector.
You said, "brand new everything", does that also mean spark plug leads?
Also, what kind of new parts, OEM Honda, good after market or cheap aftermarket, DOA parts is not uncommon, even OEM parts.
Just a FYI, the PGM-FI Main Relay is repairable 99% of the time, so do not toss the old one, repair it and keep it as a spare...
http://techauto.awardspace.com/solutions.html 94
Old Oct 15, 2013 | 10:30 AM
plugs, leads, ngk for brand. main relay is just hangin out in the garage. i guess ill fill the tank with stp injector cleaner and see if that frees up any debris. i hope this isnt electrical haha
Old Oct 15, 2013 | 12:27 PM
4doorpimpn's Avatar
A little more of a reach, but i had a very similar problem... with the throttle response and loss of power... mine was running hella rich. I had a bad Coolant Temp Switch. These run a number of different components. Also check ICM connections in the distributor. I had to clean the four wire connections to the ICM and re-lube with some dielectric grease. Good Luck!
JasonST
15
Mar 10, 2022 08:46 PM
atmdc
Mar 6, 2010 03:10 PM
steronz
21
Jun 10, 2007 08:50 AM
Seatown
Dec 17, 2006 06:26 AM
psicrxsi
11
Oct 1, 2003 09:15 AM
