widest 4x114.3 wheel BY honda
Old Sep 29, 2013 | 07:35 PM
89ED's Avatar
Default widest 4x114.3 wheel BY honda
if it is not obvious enough. im asking what is the widest wheel made by HONDA with a 4x114.3 bolt pattern?
Old Sep 30, 2013 | 04:32 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: widest 4x114.3 wheel BY honda
Pretty sure all the 15" wheels on 90-93;04-97 Accords, 92-96 Preludes were all the same width. '97-'99 CLs had 16" wheels but I still think they were the same width as the 15"s.
Old Sep 30, 2013 | 06:26 AM
NZXTInerTia's Avatar
Why would you want a wide wheels? For dat stance lyfe?
Old Sep 30, 2013 | 09:17 AM
JDMaccordwagon's Avatar
Maybe for more grip?
Old Sep 30, 2013 | 12:00 PM
89ED's Avatar
GRIP>stance
tha class rules state wheels must be stock but do not say they must be from the matching year or model just from the same company.
Old Sep 30, 2013 | 01:53 PM
Originally Posted by 89ED
GRIP>stance tha class rules state wheels must be stock but do not say they must be from the matching year or model just from the same company.
Oh, I didn't even see that it was you. In certain cases a wider wheel base can actually decrease traction, but in your case you should be fine. I'll be running a fairly wide/thick tire on my Accord when I get to that part of my build.
Old Sep 30, 2013 | 02:02 PM
89ED's Avatar
didnt really answer the wheel question but thanks for recomending a wider tire. if the widest i find is 6 inches then the widest i can go is 205 yes or no
Old Sep 30, 2013 | 03:14 PM
Sleeper EM1's Avatar
Depends on the Sidewall and/or Tire Design.
You may be able to shove a 225 on there.
Of course it'll be bulging but they will be on there.
I believe Miata guys do it all the time in Stock Class Auto-X.
Says no limit to tire size but must use stock wheels.
Old Sep 30, 2013 | 10:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Yeop, think 205/55 was for the Prelude and a slightly taller 205/60 for the V6 Accord.
Can you use Acura wheels? The 16" CL wheels would reduce sidewall for better response.
Old Oct 2, 2013 | 01:28 PM
89ED's Avatar
will any of the CL wheels work?
and is there anyone in the 626 SGV area that has 2 they want to sell
Old Oct 2, 2013 | 01:34 PM
89ED's Avatar
if found this but it doesnt give wheel sizes
http://www.discountedwheelwarehouse...._Reference.cfm
Old Oct 2, 2013 | 01:44 PM
89ED's Avatar
i made it a little easier these are all the 4 lug wheels but which one are 16 inches
YEAR MAKE MODEL Bolt Pattern
1998 Acura CL 4 lug 4.5 inch or 114.3mm High Positive Offset
1999 Acura CL 4 lug 4.5 inch or 114.3mm High Positive Offset
2000 Acura CL 4 lug 4.5 inch or 114.3mm High Positive Offset
1986 Acura Legend 4 lug 4.5 inch or 114.3mm High Positive Offset
1987 Acura Legend 4 lug 4.5 inch or 114.3mm High Positive Offset
1988 Acura Legend 4 lug 4.5 inch or 114.3mm High Positive Offset
1989 Acura Legend 4 lug 4.5 inch or 114.3mm High Positive Offset
1990 Acura Legend 4 lug 4.5 inch or 114.3mm High Positive Offset
1996 Acura TL 4 lug 4.5 inch or 114.3mm High Positive Offset
1997 Acura TL 4 lug 4.5 inch or 114.3mm High Positive Offset
1998 Acura TL 4 lug 4.5 inch or 114.3mm High Positive Offset
1992 Acura Vigor 4 lug 4.5 inch or 114.3mm High Positive Offset
1993 Acura Vigor 4 lug 4.5 inch or 114.3mm High Positive Offset
1994 Acura Vigor 4 lug 4.5 inch or 114.3mm High Positive Offset
1995 Acura Vigor 4 lug 4.5 inch or 114.3mm High Positive Offset
Old Oct 7, 2013 | 05:38 PM
chrisnick's Avatar
99% sure the widest Honda 4x114.3 wheel came on the Prelude SE's(92-96) and were 15x6.5. Lots of Nissan wheels are 16x7 and 15x7, though. 7" wide is plenty for the street and the available tires that will fit properly in the Accord wheel wells.
Old Oct 9, 2013 | 02:02 AM
MAD_MIKE's Avatar
MM Gruppe B
'97-'99 CLs used the 16" wheel and 114.3mm x 4 BP. Although I do not know if this was standard or an option.
Old Oct 9, 2013 | 06:15 AM
jdm92_accorn's Avatar
have you ever thought about a 5 lug conversion? on the accords its actually very easy. if they allow wheels from any year as long as its oem honda, id imagine brakes are the same story and hubs aswell.
audaes
Dec 15, 2009 11:20 AM
Sean @ ESG
Nov 26, 2008 07:32 PM
BlueIntegraBoy
Wheels
Nov 11, 2008 05:27 PM
CRX Toad
Jan 17, 2005 09:29 AM
Stinkycheezmonky
37
Apr 23, 2004 04:17 AM
