96 civic front driver side near motor mount...HELP
Old Sep 29, 2013 | 02:44 PM
73bowtie350's Avatar
Default 96 civic front driver side near motor mount...HELP
Whats up noticed on my car today , that it has a crack about 3 inches near the motor mount , I figure I can weld a heavy duty plate over it to keep it from opening more, looking for opinions
Old Sep 29, 2013 | 03:57 PM
Default Re: 96 civic front driver side near motor mount...HELP
Bump..
Old Sep 30, 2013 | 05:20 AM
Bump for some HELP
Old Sep 30, 2013 | 10:32 AM
that-guy's Avatar
you need to get rid of all of the paint and such first to assess the damage, then opinions will flow
Old Oct 1, 2013 | 07:21 PM
DB8 RHD's Avatar
So you need to post least 10 good pictures of the area and around it.
Coming from working at a body shop, that seem sealer is not factory and it looks like that panel was replaced, not welded well, and painted.
just from that one picture, I would tear it all apart in there, clean it up and re weld it.
Old Oct 1, 2013 | 09:03 PM
Thanks
Old Oct 1, 2013 | 09:06 PM
I will get more pics up, also I can tell it was hit before on the driver side, and looks like they went cheap on the body shop fix, will I have to drop the motor or just remove motor mount
Old Oct 2, 2013 | 02:25 AM
DB8 RHD's Avatar
Get the car where you want it, put it on jack stands, then support the motor and its fine to take off that mount.
I would pull off everything on that side, clean up everything, beat what you can back into place, and weld it all up. You could add some plating to the inside or inside the wheel well to add strength, that's about it, seam seal it, paint it. Probably a 2/3 day job, mainly waiting for stuff to dry.
Looks like a crap repair job, I would fix it and sell it and buy a car without previous damage. my 2 cents.
Old Oct 2, 2013 | 05:11 PM
Sounds good , but will just strengthen it up, and go! Not going to be a daily driver anyways, gonna throw a dohc motor and use it as a weekend warrior! GREAT INFO
Old Oct 3, 2013 | 04:19 AM
Wondering what gauge metal to use and for the inner wheel well too
Old Oct 3, 2013 | 04:35 AM
that-guy's Avatar
i typically do these types of repairs with .050" mild steel, and turn the heat up on the welder to get the best penetrationg without blow thru. it's thicker than the factory metal and should add some strength
Old Oct 5, 2013 | 05:51 PM
DB8 RHD's Avatar
Anything over a 1/8" Id use, the factory sheet metal is crap and burns threw super easy / quick. Fix it proper, make it look good and sell it.
Old Oct 7, 2013 | 05:31 AM
Thanks for the info
SRd240sx
Northern California
30
Jan 12, 2010 07:56 AM
freddybnb
Paint and Body
Nov 16, 2009 01:02 PM
coupe_hybrid
Feb 25, 2005 04:36 PM
RzHybrid510
Jan 13, 2005 05:46 PM
CALM_AS_A_BOMB
Jun 2, 2004 09:48 AM
