'92 Accord Starting Issues
Old Sep 28, 2013 | 02:30 PM
egiboo487's Avatar
Icon6 '92 Accord Starting Issues
I have been having some troubles with getting my car to stay on. When I turn the key the car will fully turn on but once i let go of the key it just shuts off right away. I have replaced the Fuel Filter and the Main Relay after reading some other posts on this site but neither of those worked for me. I think this problem could be happening because I had over-filled my gas tank and it stopped working the day after I filled it up. Please post ideas and thoughts on what I can do to get it working again, Thanks!
PS: Not sure if this will be of any help but I also cant get the A/C to turn on while having the key in the #2 position before you start the engine.
Old Sep 28, 2013 | 04:04 PM
drummer1279's Avatar
Default Re: '92 Accord Starting Issues
It sounds like your ignition lock cylinder has went bad. not too terrible of a job to replace.
Old Sep 28, 2013 | 04:53 PM
egiboo487's Avatar
Should replace the wiring and everything or just that one part?
Old Sep 28, 2013 | 04:57 PM
just the lock cylinder
Old Sep 28, 2013 | 05:40 PM
egiboo487's Avatar
would this be the correct part?
http://www.autozone.com/autozone/par..._319620_0_4299
Old Sep 28, 2013 | 11:42 PM
holmesnmanny's Avatar
Yes. It's fairly easy to replace. There is a pin that you need to push in with the key in the correct position. Just use a paperclip or a pick. Then the key will pullout with the lock cylinder.
Use the new lock cylinder to tell you what position it needs to be in to remove the old lock cylinder.
Old Sep 29, 2013 | 04:29 AM
Lost Again's Avatar
Just me but I would replace the electrical part of the ign switch.....not the lock cyl.
Key to on....check for voltage at the BLK/YEL wire at the dist? If none, replace the electical part of the key switch.......35130-SM5-305 is the OE part number, double check this as I assumed a few options.
Old Sep 29, 2013 | 06:04 AM
If he is having to physically hold the key to keep the car running, then its the lock cylinder that is shot. I had the same problem 8 months ago.
Old Sep 29, 2013 | 06:09 AM
Lost Again's Avatar
Could be...but I've seen the elect part fail at least 10 time more than a lock cyl? Also note the simple test to be sure.
And for more reading: http://techauto.awardspace.com/ignitionswitch.html
trailshredder
Sep 4, 2008 07:12 AM
paceman
Jan 14, 2008 11:57 AM
timhillu03
Dec 21, 2005 04:14 PM
BrodyH
Aug 7, 2005 08:57 PM
NIUdirtsac
Aug 29, 2004 11:31 PM
