91 Accord rev only in drive, reverse works.
At first I thought the transmission was going out. Or it was the tranny filter, because if I turned the car off then back on, it would go. But after a little research, discovered there's multiple sensors that it could be. I started with the TCU. That didn't work. It still starts, reverse works, but when in drive it only revs. There is no forward momentum. Which sensor would cause this, and where's its location?
