Best D engine for boost? Questions.
Old Sep 27, 2013 | 11:36 AM
ForeverSupra's Avatar
Default Best D engine for boost? Questions.
I was thinking the D16Z6. What do you guys think? Im trying to go with an easy swap.
I've read this swap guide: http://www.ef-honda.com/ben/EFswapguide.html
It says: "D-series. Your car comes stock with a d-series engine. These bolt right in with out mount kits. You can use your stock shift linkage, axles, mounts, and even the tranny if you want (you'll want to find an Si one)."
Is this true even when the engine is from a different generation?
Old Sep 27, 2013 | 11:38 AM
OGxruiner's Avatar
Default Re: Best D engine for boost? Questions.
http://lmgtfy.com/?q=d16z6+into+ef+swap
Old Sep 27, 2013 | 12:07 PM
Originally Posted by OGxruiner
Thanks a lot. I guess all D engines do bolt in, it said the same thing for the Z6.
Edit: Having a hard time finding a Z6... I'm going to look at the DOHC ZC.
Old Sep 27, 2013 | 01:43 PM
Freemananana's Avatar
Whoa, hold it cowboy. You think the Z6 is hard to find. That DOHC ZC will be a bitch to get replacement parts for. It's not that common of a motor. If you are going D series for boost, set your goals at a respectable amount or look to spend a lot of money. Stock D series motors aren't known for putting down the highest numbers around.
The Z6 is my favorite D series motor when going for boost.
Old Sep 30, 2013 | 06:35 AM
I was looking at buying it online from a trusted source and they dont seem to have any on the sites I checked. I see a lot of ZC for sale... Id hate to buy something at a junkyard thats beat to hell and end up screwed.
I dont plan a lot of power anything is better then this beat up d15 that came with the car. I want a replacement and a small turbo for a little bit more of power.
Any sites I should look into for the Z6? Or maybe theres plenty in honda techs market (just thought of that) but I dont have access yet.
Old Sep 30, 2013 | 06:44 AM
fallrivercolin's Avatar
You're looking into spending a lot more money than you think to boost a Honda. My advice is to find a DOHC ZC and do your first swap with that. Then, after you have that under your belt, think about boost
Old Sep 30, 2013 | 06:51 AM
Market place is a good spot and hmotors is an online website that is great for motors. Don't buy an eBay motor. Haven't heard anything good about the importers on there. But it could be different now days.
Old Sep 30, 2013 | 07:21 AM
dueyx99's Avatar
sounds like you got a long road ahead of you, you have alot to learn from this point on, lots of good builds on this site as well as D-series.org, get to readin' son!
Meatwad1355
19
Dec 25, 2011 09:00 AM
awd_ef_sedan
Apr 21, 2010 09:27 AM
cjwarren4dcivic
Apr 6, 2006 05:59 AM
bensonwrx
16
Jan 7, 2004 10:31 AM
Jeff_G
Jul 15, 2002 10:12 PM
