Accord 92 oil in sparkplug well.
G'day!. - have some oil in sparkplug well 1 & 2. - Just how are the chances of getting rid
of the oil leak by only replacing the upper 4 o-rings?
Thanks in advance!
Thanks in advance!
The spark plug tube seals are 4 seals that are underneath the rocker arm assembly. This is in addition to the 4 orings that are just under the valve cover assembly.
In the faq's at the top of this subforum you can find a guide on how to replace them.
Just my 2 cents.
Just my 2 cents.
Not only is it uncommon for the lower seals to go bad, but by replacing them you risk destroying the entire top end of your engine.
Don't tell me what to do or what not to do. You have no clue what you're doing. I tend to know what I'm talking about.
I don't know what you're basing your information on but the lower seals go out on these f series sohc cars all the time. Just do a search. Just because you've only worked on probably one car doesn't mean that is representative of most cars on the road.
Again, I know you're only goal at this place is to get a rise out of people but still. Just stop.
Gentlemen! - Allow me to stay neutral on this subject!......Wanted some information
on how frequently people get away with just replacing the upper ones as unfortunately
a lot more work is needed to get to those underneath the rocker assembly!
But thanks to both of you!
honda has serious oil leaks
