Strut replacement
Old Sep 26, 2013 | 07:24 PM
shortlid's Avatar
Icon2 Strut replacement
I am looking to replace the front struts on my '99 accord EX sedan with 188k on the clock. I have seen some $65 complete drop in strut assemblies. Anyone done this job, does it hake the car ride and handle alot better? Any inexspensive brands you can recomend?
Old Sep 26, 2013 | 08:00 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Strut replacement
If the shock is blown and the spring is sagging, replacing both would bring the ride height and quality back.
None that I can think of, I would not cheap out on dampers as they greatly contribute to ride quality. Cheap dampers may not be correctly valved for the spring/car and may cause for a harsh or marshmellow ride.
If the original dampers are still installed, they may be KYBs, if you look at them you will see a large 'KYB' stamped on the tube. If so look up KYB dampers/complete assemblies. They can be found for good prices through some of the larger online retailers.
shortlid
Jul 9, 2009 09:36 AM
littledude56
Suspension & Brakes
May 6, 2009 03:47 PM
96delo
May 29, 2008 07:12 PM
95lstegman
Suspension & Brakes
Jun 7, 2005 07:40 AM
972drcordex
Feb 4, 2004 05:53 AM
