80 lbs of torque at the lugnuts!?!?!?!?!
Old Oct 26, 2002 | 11:47 AM
WheAs MaI MojO's Avatar
Default 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky!
Ok 2 weeks ago, i rotated my tires and i tightenened my lugnuts at 80 ft lbs of torque. yerterday, i was cruisin down the 101N freeway and i heard some nasty grindin noises comin from my front left tire......i pulled ova immediately and noticed that the lugnuts were loooOOOOOoooOOoOSe!!!!!!!!!!!! to a point where u can take them off with fingers....oh my i fainted. and after i woke up, i tightened it. what happened??
Old Oct 26, 2002 | 02:44 PM
Nick M's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (WheAs MaI MojO)
Did you miss that wheel?
Old Oct 26, 2002 | 02:50 PM
GSRrR's Avatar
Did you tighten it in a star pattern?
Old Oct 26, 2002 | 03:44 PM
Chiovnidca's Avatar
what happened??
Are you using the proper lug nuts?
Old Oct 26, 2002 | 04:49 PM
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (Chiovnidca)
yes, yes and yes. yet it still came out. BAh......wutevers.....its only one wheel
Old Oct 26, 2002 | 04:56 PM
sloaccord96's Avatar
make sure its tuners lugs.....you don't want to have the same sht tha happened to me happen to you
Old Oct 26, 2002 | 04:59 PM
D114's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (sloaccord96)
On aluminum and mag wheels, you are supposed to tighten it to the preset amount... and then retighten it after 25 miles or so. I just crank mine down to whatever the impact wrench takes to. (200ft/lbs or so) I've never had a problem with that.
Old Oct 26, 2002 | 07:59 PM
VRGNCD5's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (D114)
overtightening is a contributing factor to warpped rotors, FYI.
Old Oct 26, 2002 | 08:25 PM
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (94uhkord)
and FYI, there is no such thing as a "warped rotor" on the face of this planet. Try doing a RESEARCH.
Old Oct 26, 2002 | 08:27 PM
bmm89's Avatar
true on all counts, don't over tighten too much, and you have to check again after 75 miles so so... but honestly, 80lbs is plenty unless you have the wrong type of seating nuts... or a bad torque wrench.
Old Oct 26, 2002 | 08:33 PM
Chiovnidca's Avatar
LMAO No such thing as a warped rotor, huh? I'd love to see your research.
Old Oct 26, 2002 | 08:49 PM
Kazmans94cord's Avatar
dude...did you really faint?
Old Oct 27, 2002 | 06:11 AM
JRZYACCORDRACER's Avatar
there is a such thing as warped rotors why do u think that honda has those 2 lil screws that hold the rotor on there??? thats hondas way of stopping the rotors from warping.....what planet r u from...u really shouldnt speak on things unless u know what ur talkin bout...iaght cheif
Old Oct 27, 2002 | 07:33 AM
jweller's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (JRZYACCORDRACER)
Irregardless of wether or not rotors warp. those 2 little screws do not keep them from warping or anything else. they are there to keep the rotor in place on the assembly line.
Old Oct 27, 2002 | 08:28 AM
4doorH22's Avatar
80 ft lbs and re-torque in a couple of weeks. Hell I torque them every couple weeks, it only takes a minute (and never-ever found one to be loose).
Also wheels and lugs have either flat, rounded, or taped seating surfaces, so make sure your wheels and lugs match. A very common problem is that OE Honda lugs are rounded, they work well with many aftermarket wheels, but it seems most aftermarket wheels perfer a tapered lug.
Old Oct 27, 2002 | 08:38 AM
4doorH22's Avatar
Oh there is such a thing as a real warped rotor, but it's usually due to a very, very, very, very rare manufacturing or assembly defect.
Old Oct 27, 2002 | 09:31 AM
sparknblaze's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (4doorH22)
I've gotta question: I need to replace my lugs. Do they have to be machine pressed or can they just be hammered in & out? 1995 accord wagon ex w/abs if that matters
[Modified by sparknblaze, 2:34 PM 10/27/2002]
Old Oct 27, 2002 | 09:36 AM
4doorH22's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (sparknblaze)
You mean the studs?
Easy pound out and in with a 5-lb hammer, but the hard part is getting the hub off and on. Well, rear is easy, front can be harder.
Some people do it leaving the hub on the car and torquing nuts on the studs until they are seated. I think in the end the remove-hub-and-hammer method is less infuriating.
Edit: What you don't want to do is use the hammer method with the hubs on the car... you'll really shorten the life of your wheel bearings with the pounding.
[Modified by 4doorH22, 1:42 PM 10/27/2002]
Old Oct 27, 2002 | 09:43 AM
My fault you were right. It's the studs I need to replace. Thanks for the info.
Old Oct 27, 2002 | 09:52 AM
Chiovnidca's Avatar
I say warped rotors are usually caused by excessive heat. And it's not all that rare either.
Old Oct 27, 2002 | 10:41 AM
Hey... My mechanic said the hub on my car has to be machine pressed on/off. True/false? 1995 accord wagon.
Old Oct 27, 2002 | 10:45 AM
Accord94DX's Avatar
True.
this thread makes me want to shoot myself.
Old Oct 27, 2002 | 11:17 AM
juicedh22's Avatar
Default Re: 80 lbs of torque at the lugnuts!?!?!?!?! bullshitsky! (Accord94DX)
Yea...pretty fuggin weak thread...no such thing as warped rotors?? what r u thinking...
Some clarity:
warped rotors are more generally due to over heating
overtorquing the lugs has a larger problem on snapping/breaking your studs then it does on anything else...
And directly back to the original post..
When you put on new wheels, you torque at 80-85 ft*lbs then a day later or so, you re-torque them. (this is especially important on new wheels and 17"+ wheels)
Old Oct 27, 2002 | 11:26 AM
Chiovnidca's Avatar
Yea, alot of bullshit gets posted here sometimes.
BTW, who's stopping you?
Old Oct 27, 2002 | 11:34 AM
4doorH22's Avatar
True.
Mmm my friends and I have always gotten the hubs off and on by hand. There are a couple different methods. To get the wheel bearing out though, that needs a press.
