99 CRV what else to replace when replacing all belts
Old Sep 25, 2013 | 01:57 PM
npt0817's Avatar
Icon6 99 CRV what else to replace when replacing all belts
I am replacing all the belts on my 99 CRV what else should be replaced at that time? Looking for suggestions.
Thanks for everyone's time.
Old Sep 27, 2013 | 03:47 PM
swordofdoom's Avatar
Default Re: 99 CRV what else to replace when replacing all belts
I have had to replace:
Distributor cap and rotor
spark plugs
Rear differential fluid
Thermostat
Water pump
valve cover gasket
Coolant flush
Cam seals
Crank seal
Timing belt idler
All the belts
This was done on a 99 CRV with 200K miles. So yours may be different depending on mileage.
Misc other stuff replaced:
Trailing arm bushings
Rear brake shoes
Front arm bushings
Lower ball joint
All the struts
All the sway bar bushings
Valve lash adjustment
Old Sep 28, 2013 | 12:18 AM
holmesnmanny's Avatar
just get a timing belt component kit w/ water pump
Old Sep 28, 2013 | 05:32 AM
HondaPartsHero's Avatar
Technical Hero
How skilled a mechanic are you is a better question?
greeen ranger
51
May 12, 2013 08:27 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
tina
Acura TL, RL & ZDX
Sep 19, 2004 05:44 PM
Teggyb18b
Nov 20, 2002 05:57 PM
nek0
Sep 26, 2002 10:46 PM
