96 Accord LX cooling fan stays on after engine bay is detailed.
Old Sep 23, 2013 | 06:59 AM
JDM_rolex's Avatar
Default 96 Accord LX cooling fan stays on after engine bay is detailed.
Hey guys my brother picked up a 96 accord and the engine was a tad dirty. The car itself runs smooth and has no known issues. The fan worked fine before it was sprayed with degreaser and pressure washer.
I sprayed some engine degreaser in the bay and then followed it up with a pressure washer to the engine bay. After we finished spraying the bay we started the car and let it run to dry up settled water around the engine bay.
Once we took the key out of the car the fan turned on. I just thought that it was just cooling itself, however after 30 minutes the fan was still on. The only way that I was able to turn off the fan was to unplug it. Currently the fan is out of comission.
Anyone know what I can do to fix this problem? I don't want the cooling fan to be on for hours and drain the battery.
Old Sep 23, 2013 | 03:22 PM
Lost Again's Avatar
Default Re: 96 Accord LX cooling fan stays on after engine bay is detailed.
Check that thermo b - green two wire connector where the upper hose connects to the engine is clean and dry.
We'll assume the cooling system is full and no air trapped.
Old Sep 24, 2013 | 10:58 PM
holmesnmanny's Avatar
Could also be the fan timer since you said fan and not fans. This assumes you don't have ac.
Old Sep 25, 2013 | 04:30 AM
JDM_rolex's Avatar
Lost Again, do you mean the Thermostat?
The car does have AC however the AC condensor fan does not turn on, only the cooling fan for the radiator comes on. Where is the fan timer?
I don't work on Accords so this is a bit new to me.
Old Sep 25, 2013 | 08:49 AM
Lost Again's Avatar
The t-stat housing (lower hose) has thermo a. Thermo a only controls the fans when the key is on or engine running.
Thermo b controls the fan when the key is off.....where the upper hose connects.
Old Sep 26, 2013 | 08:44 AM
mrj_accord's Avatar
also check the relays in the fuse box under the hood on the passenger side.
they cost about 15 bucks at the dealership.
Old Oct 5, 2013 | 10:14 AM
a25afm's Avatar
I have a 2007 Honda civic. Both cooling fan stay on after the engine is shut down. The fans are on low speed and will run till the battery is dead. I unplugged the two thermo switches, one by the thermostat and the other at the bottom of the radiator. Fans still run. Any ideas?
Thanks
Alex
Old Oct 5, 2013 | 11:16 PM
Now pull fan relays. Whichever one stops the fans is the fault. The fan timer shouldn't be the issue since it will only turn on the radiator fan. There is a control unit. If the relays aren't the issue it could be the control unit.
Jason Galatz
Aug 8, 2013 03:28 PM
mrader
Jun 13, 2010 06:35 PM
dirty_sancho
May 12, 2010 07:36 AM
Roster99
Jun 7, 2005 12:40 PM
LB CRX
Nov 22, 2002 06:53 AM
