obd0 Y7 crank, no start.
I swapped a d16y7 into my 91 CRX DX, I also converted to mpfi with the swap, I'm getting fuel to the rail, my wiring is dead on, I flipped the TPS wires, and I'm using a brand new TD-02 (Si) distributor, It'll crank but won't start, The rotor is turning inside, I just need some ideas as to what the problem could be.
using 240cc injectors with resistor box
PR4 ecu
PR4 ecu
PR4 ecu
PR4 ecu
Is the y7 OBD1? I'm pretty sure you have an OBD1 ECU with an OBD0 distributor. I could be wrong. But I think you have the wrong distributor.
If it's not grounded, it's not dead. At least thats what the electric dept of our city says. Are your 3 major grounds good? Trans, thermostat, and valve cover.
@Freemananana Yes, all 3 grounds are in place and solid, and no I pulled the ecu from a 1991(obd0) Integra, and simply plugged it into my harness.
http://www.phearable.net/tech/wiring/pinouts2.htm
If you're fairly certain you don't have spark, I'd recommend that you verify you are receiving power to the distributor and go from there.
Also try taking one of the wires out and cranking the motor to see if there is spark. Best to do with 2 people and a fire extinguisher if you're not careful. (Spark and gas vapors from the cylinder=/=good)
No, when I tested the dizzy twice the first time it would fire on cylinder 3 then later that afternoon when I tested it again it would fire only on cylinder 1, I'm thinking there's something wrong with the wiring.
That was my next step, I'm gonna replace the injectors with saturated injectors that came off the swap, I've had them soaking brake clean so I know they aren't clogged. I just need to go to the pull a part for injector plugs
IT'S ALIVE
double checked all connections. dizzy pins weren't fully in the plugs and the teeth that mesh with the cam in the dizzy were 180 out of time.
It's runs perfect no check engine lights
