Integra 2002 Auto Trans oil - Nulon?
Old Sep 23, 2013 | 01:01 AM
Tech123's Avatar
Default Integra 2002 Auto Trans oil - Nulon?
I have a Honda Integra, 2002, 2.0L (Note: NOT a Type R - just standard 2.0L), automatic with approx 210,000 klms on the clock. I am going to do the next service myself and I just wanted to verify that I am using a safe and quality auto transmission oil that will cause me no problems
SuperCheap Auto was having a 20% off sale so I purchased the following oil:
Auto Transmission oil: Nulon 100% Synthetic, Multi-Vehicle
Suitable for "Dextron II, Dextron III, Dextron VI"
"Compatible with Honda ATF Z1"
As far as the automatic transmission oil goes I rang Honda spares and was advised I should use Honda ATF DW1 which is the upgrade of Honda ATF Z1. I asked the Honda spares guy if the Nulon 100% Synthetic Multi Vehicle oil would be OK. He said he wasn't sure but said a local auto transmission repairer uses the Honda DW1 as well
I then rang two reputable professional automatic transmission repairer's/service businesses (asked to speak to a knowledgeable mechanic) and advised them of the above Honda and Nulon ATF oils. Both said that the above Nulon ATF oil should be OK for the Honda 2002 Integra. One said that Honda put in certain additives in their ATF oil for gear changes. Another said that Honda DW1 is a mix of synthetic oil and normal ATF oil, not 100% synthetic. So I said the Nulon 100% synthetic is overspec isn't it, so it should be OK if not better. He said it should be OK for the 2002 Integra.
I actually rang Nulon HQ in Sydney and explained the above in detail for the Integra 2002 series VTI 2Ltr, auto trans. Nulon said that the 100% Synthetic, Multi Vehicle oil would be OK to use. I said that on the Nulon oil bottle specs it said that it is compatible (equivalent) with Honda ATF Z1 and Honda says that they have upgraded their oil to ATF DW1 - why then isn't that spec on the Nulon bottle specs (only ATF Z1). Nulon said that "we can't update specs on bottles for every car, but that 100% synthetic will be fine for your car"
With the above checks I feel reasonably confident that the Nulon Multi Vehicle 100% synthetic ATF will cause no problem and perhaps work even better as it is over specifications being 100% Synthetic ATF
If I've made a mistake or been mis-advised please let me know? If mis-advised specifically whats wrong with the Nulon oil as has top quality specs and so far no one has faulted it for 2002 Honda Integra use?
Old Sep 23, 2013 | 07:23 AM
B_Swapped93's Avatar
Default Re: Integra 2002 Auto Trans oil - Nulon?
wrong integra section you want the RSX one.
Curated Content Editor
Honda-Tech News
28
May 23, 2018 05:42 PM
mcgradiator
Aug 7, 2008 06:54 PM
1.6vx
Mar 16, 2008 10:53 PM
d15bdelsol
16
May 26, 2007 01:21 PM
