THIS SHOULD BE A STICKY!!!
Old Sep 22, 2013 | 10:17 PM
mint95gsr's Avatar
Default THIS SHOULD BE A STICKY!!!
During my recent turbo project i decided to delete my ABS on my 95 GSR. Once i started driving the car to work out the bugs i noticed my speedometer wasn't working. After trying different sensors and checking plug and wire for faults i couldn't figure it out. Long story short i cut the plug off my ABS harness in the passenger wheel well. The ground wire for the VSS is part of that harness. So if you are having VSS problems and just deleted ABS splice into the black wire on the VSS plug and ground it out. (i attached mine to the ground spot on thermostat.) After that speedometer is working perfectly. I DO NOT KNOW if this is the same for all integras with ABS but it definitely was that way on my 95 Integra GSR. HOPE THIS HELPS SOME PEOPLE!!!! GOOD LUCK OUT THERE
Old Sep 23, 2013 | 01:53 AM
raverx3m's Avatar
Default Re: THIS SHOULD BE A STICKY!!!
lol how many stupid people are gonna cut wires
you re one of many that did same ****.
check before cutting wires...
UNPLUG IT TAPE IT and TUCK IT somewhere don't cut
Old Sep 23, 2013 | 06:15 AM
HondaPartsHero's Avatar
Technical Hero
Kinda like all these wire tuck issue threads lately from diy'rs. You just cut, lengthened, shortened and soldered 100 of wires, I don't even go near those threads.
red96turbols
Oct 20, 2011 07:51 PM
trrbl1bmx
Mar 7, 2010 02:40 PM
10sec4door
Feb 11, 2010 08:41 AM
Jspek_Inspired
Sep 25, 2009 01:54 PM
DC2 Mang
Nov 28, 2006 11:35 AM
