1995 Accord Transmission Issues
Old Sep 22, 2013 | 07:21 PM
rufus13ky's Avatar
Default 1995 Accord Transmission Issues
I have a 1995 Honda Accord which has been giving me some trouble lately. Recently, on occasion, the spedometer will begin move erratically and the d4 light will begin flashing. When I stop the car, turn it off, and restart it, the problem rectifies itself for a while. I pulled the transmission fault codes and got 4 (vehicle speed sensor) and 15 (main shaft speed sensor) I also received the VSS fault code from the ECU. Is this all related to the same problem or seperate issues.
Old Sep 22, 2013 | 11:05 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1995 Accord Transmission Issues
Codes 9 and 15 are related to the two magnetic sensors located on the right side cover of the AT housing. Use a 10mm wrench and pull the two sensors, make sure they are clean of any junk, slurry, and that the wiring is good and the sensors resistance is within spec.
Scroll half way down this page to read up on the NM/NC sensors > http://techauto.awardspace.com/transmission.html
About directly underneath where the throttle body is, located in the differential housing is where the VSS is located. Sometimes the sensor can be pulled apart, cleaned, reinstalled and it works again. But it may need to be replaced.
http://techauto.awardspace.com/vss.html
vanyawatson
Sep 28, 2022 09:30 PM
davidalarcon12
Oct 15, 2011 07:14 PM
blakenshake8
Feb 9, 2011 06:04 PM
refman102
Oct 25, 2007 05:24 AM
Zerob16eg
Jun 16, 2007 12:29 AM
