Key wont come out of ignition
I just bought a 99 civic its auto matic the key wont come out of the ignition unless i unplug the brown plug from the fuse box what the hell is the problem any help is appreciated thanks
When you put the car in park there's a solenoid behind the lock cylinder that either opens or closes that allows the lock cylinder to turn so, yeah, something to do with that system.
Adjust the A/T Gear Position Switch, this is a common problem on G2 Integras', but I have not heard about it on 99 Civics.
It may also be a bad, A/T Gear Position Switch or wiring to/from it.
You have checked fuses, right? 94
loki2010
Dec 30, 2010 07:18 AM
honda314
Aug 19, 2009 10:25 PM
twinlord1
Nov 13, 2006 03:09 PM
