GSR swap running terrible
Old Sep 21, 2013 | 02:14 PM
superslowcrx91's Avatar
Default GSR swap running terrible
So my car was running alright and i decided to do an oil change and make the switch to full synthetic. I decided to go with 5W20 valvoline full synthetic. Now the car is boggy and slow and runs like crap. Overall when it goes to engage Vtec it bucks hard and wont go anywhere. I feel like it has something to do with maybe not building enough oil pressure but i cant seem to find any information on this. I figure it has to be the oil because it ran ok before hand. Also running a stock honda oil filter. Im going to see about getting a pressure tester to check it out. Also no check engine light.
Old Sep 21, 2013 | 06:44 PM
Default Re: GSR swap running terrible
So the oil doesnt appear to be the problem. Went to walmart and got castrol gtx 5W30 conventional and did another change. I used an OEM honda filter, is it possible the guy at honda gave me the wrong filter i was under the impression that all honda filters were the same but it was much smaller than the filter i previously had. Again no check engine light, good fuel pressure etc. The car ran fine 3 days ago.
Old Sep 21, 2013 | 07:10 PM
Freemananana's Avatar
You didn't hit anything else while you were changing the oil, did you? That's a weird thing to happen just because you changed the oil. Unless something really unfortunate happened. It's probably just an electrical bug that you'll find soon. Usually boggy and slow means tps.
Old Sep 21, 2013 | 07:23 PM
i've checked the tps a bunch of times and its fine. .5-4.5 all the way through. It bucks hard at like 5000 rpms and vtec engages but there is no power at all. i could barely make it up my hill today.
Old Sep 21, 2013 | 09:25 PM
swordofdoom's Avatar
Check your cap and rotors and sparkplug.
Old Sep 22, 2013 | 05:43 AM
Always good to start with the easy things.
You may want to do a compression test just to make sure you didn't some how lose a piston ring. But it would be smoking if that was the problem.
A loss of power over an oil change is weird. There had to be something that happened. Have you checked your motor grounds? I've seen that make cars run terribly.
Old Sep 22, 2013 | 06:25 AM
Yeah I plan on doing a compression check just have to go pickup the tester. As for smoke none at all, and the car idles perfectly. I'll check the grounds today but I really doubt it's a faulty ground. It almost feels as of the car is clogged up somewhere. I've heard cheap cats can shatter and cause a blockage so I'm also gonna check that today. I just put a new rebuilt distributer on less than a month ago as well.
Old Sep 22, 2013 | 08:42 AM
For checking the cat, just use a laser thermometer. It should be hotter after the cat.
I have seen grounds cause bogging and issues that seem like a bad TPS. But it will idle normally. There is actually a guy on this forum in the past week that had a bad valve cover ground that was causing his car to bog.
Old Sep 22, 2013 | 09:05 AM
Well i think its safe to say we can shut this thread down. I had this suspicion about a clogged exhaust so i decided to look in...
after much poking and prodding no budge so i cut where the blockage was and this is what i found...
i cant get it out whatever it is is jammed way into the mufller and wont budge
Old Sep 22, 2013 | 10:24 AM
Get the cat out of your muffler.
Aphrodavid
Apr 7, 2009 07:39 PM
Aphrodavid
Apr 5, 2009 09:50 PM
twentyhurtz
Oct 18, 2007 05:11 PM
SIvic2000
14
Feb 19, 2007 07:22 PM
