Adding skunk2 exhaust tip
Would adding a skunk2 muffler onto my civic si make the car sound deeper? Or do i need to get the full exhaust system to get a deep sound. Im on a really tight budget as i am a college student
No, if i cant spend $200 or less to make my car sound deeper or louder but a deep loud sound il probably use the money for skunk2 lowering springs
Honestly,
From some one with a lot more experience you are doing it all wrong!
Save your money and get a proper coilover suspension like the Skunk2 Pro-S II... Any mods you will do on the Si will need Flashpro.
If you want to get a little more sounds and power your best bet is to get a CAI... the Skunk2 one is probably the best one on the market right now. The Hybrid Racing is good too but they have an issue with the cuppler... Any of the CAI will need Flashpro as you will be running too lean and will cause a check engine light to come on.
If you want to an exhaust your best bet is to wait and save your money and look for either a the Full Race Exhaust which is really deep and loud enough... the NVidia Q300 is nice also its deep but not like the Full Race one.
All the guys that posted in here are right about one thing doing it right the first time will cost a little more but doing it wrong and having to redo it will cost you double of what you paid the first time! They all have been doing it for a long time and have made those mistakes and they are trying to guide you to not make them either...
I bought my Si with a 2007...Sometimes I love the Skunk2 2.5<--Assuming is 2.5mm Looks smaller then the wider one. Anyways, Sometimes I love it specially when the vtec is loud...but a lot of times it drives me insane plus I am always wondering if a copper is gonna fall in love and pull me over for noise pollution...
Honestly,
Honestly,
Bolt-ons don't NEED Flashpro, although it does help gain even more power. Installing an intake, header, and exhaust would be perfectly OK without Flashpro.
OP: If you can't afford proper mods, don't waste your money. I've never understood people who spend money to make their car worse than it was originally. The Si is a pretty decent car bone stock.
You say a proper coilover suspension, but then recommend Skunk2 Pro-S (II or not). That's an oxymoron.
Also you can do all the bolt-ons without Flashpro but then you will have to deal with all the check engine lights that will come on with it. One thing is for sure is as soon as you change your header you will have the secondary o2 sensor coming on as it won't be present and the defouler trick doesn't work.
Also if you get a CAI that is 3" or bigger you will get another check engine light that will be your car running too lean.
I know as I had these problems and the only way around it was getting Flashpro... as well as all the other members of 8th that ran into the same issues.
The Skunk2 Pro-S is highly regarded over on 8th... but to each there own. I will agree with you it's not the best suspension as better is out there guaranteed!
Not sure why the defouler in the header didn't work for you, it works for other people. Maybe yours was too short? As for the CEL coming on, did you reset the ECU after installing the bolt-ons? If not, that could be the reason for the CEL.
Do some Aesthetic mods first. Tints, LEDS interior. Outside LEDS. some HIDs, maybe plasti-dip your wheels. Clean headlights. Either plasti-dip or vinyl wrap your taillights, upgrade radio system, get a shift boot, plus a skunk2 shift ****. Get some JDM emblems. a walmart aluminum Exhaust tip. save $ for paint if needed. Remove the Intake RESONATOR. Its the one by the Drivers bumper. There are do it yourselfs, This should help your engine sound more throatier.
fortillian
May 20, 2009 11:34 AM
