Obd0 ef starts won't take throttle dies
Old Sep 20, 2013 | 08:06 PM
ruff ef's Avatar
Default Obd0 ef starts won't take throttle dies
Hello everyone I just wired obd0 dizzy conectors on my z6 dizzy to fit my obd0 d16 with z6 head. Lately the car has been being a little temperamental when starting. Since I did the dizzy a few hrs agao I haven't been able to get it running. It starts revs it's self to like 1500 rpm then instantly dies. It has no effect on the idol if you give it gas or not. After it dies, inorder to start the car again you have to shut the key off let the fuel pump kick on again then it fires back up then does the same thing. I'm stumped. Looked for the fuel pump relay, searched all over the web and can't find it. Any help at all would be great.
Old Sep 21, 2013 | 03:15 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Obd0 ef starts won't take throttle dies
Can't use OBD1 dizzy on OBD0 ECU, you need a P28.
Old Sep 23, 2013 | 07:51 AM
4drEF's Avatar
Keyboard Humorist
Z6 head and z6 distributor
What ECU do you have?
Old Sep 23, 2013 | 08:00 AM
Freemananana's Avatar
You need electronics of the same OBD.
For your motor you need the OBD1 Z6 Head, Distributor, ECU, and either OBD1 injectors or OBD0 injectors with an injector resister box.
lilsicsoul
13
Jan 26, 2009 07:20 PM
Mr_Moos
Mar 30, 2007 10:07 PM
dumped4dr
Jul 30, 2006 05:16 PM
90civicturboed
Jul 25, 2005 08:53 PM
ABK
May 6, 2004 07:48 AM
