Honda S2000 Honda S2000
ap1 vs ap2 suspension and specs question
Old Sep 20, 2013 | 05:13 PM
TheSupremeKai's Avatar
Default ap1 vs ap2 suspension and specs question
besides the engine. whats the difference in the ap1 02-03 vs the ap2 04-05? i heard that the suspension is more forgiving in terms of track racing. could it be that it is more expensive suspension or is it a certain change in the geometry in where the suspension is placed? supposedly the ap2 my04-05 has a tendency to have a toe in suspension which helps the back stay in place as opposed to the ap1 my00-01-02-03 having unintentional drifting problems and eventually wrecked rear ends. can anyone confirm this? or are the chassis the same and the displacement only changed?
Old Sep 21, 2013 | 04:23 PM
Default Re: ap1 vs ap2 suspension and specs question
Bump
Old Sep 21, 2013 | 05:46 PM
postman's Avatar
ap2's had a change in the rear to help correct bump steer. there are multiple changes throughout the years for spring and shock settings and roll bar stiffness. not just a difference in ap1 and ap2. off the top of my head id say there are 5 different setups CR included. mainly the ap1 is less forgiving than ap2.
when you start tracking the s2000, and you get the point your are driving on the edge. you definetely need to be careful as in general the s2k gets twitchy and a lot of times gives no driver feedback before it goes into an slide/oversteer condition.
typically if your capable of achieving the point of driving the s2k that well. you are seasoned enough of a driver to understand what the car is doing and what is giving you and not giving you. which ultimately will determine your setup changes and driver correction changes.
Old Sep 22, 2013 | 07:04 AM
im not a dbw throttle fan. so basically its just more expensive suspension on an ap1 chassis? just different settings? they can just be switched out right?
Old Sep 26, 2013 | 09:25 PM
bsyeth's Avatar
All parts are completely interchangeable, except the rear control arms.
The Rear subframe was upgraded in 04, but other than that its mainly spring changes and sway bar stiffness changes.
Old Sep 30, 2013 | 05:55 PM
Thank you for the big help. I've heard mixed answers but never got verification until I got 3 sources. Thanks a bunch
Old Oct 2, 2013 | 01:37 PM
Splatter85's Avatar
Here's a blow by blow with every option. For the future I googled "s2000 model year changes"
http://www.s2ki.com/s2000/topic/7553...r-differences/
descartesfool
Jun 7, 2011 09:08 PM
brattesani
Dec 29, 2009 11:27 AM
JJ's civic
Jul 15, 2006 02:53 PM
ImNaked06
Oct 1, 2005 05:42 PM
