ECU Testing
Old Sep 20, 2013 | 04:27 PM
bfpicard's Avatar
Default ECU Testing
Is there an easy way to test the ecu unit in my 1990 Honda Accord. I'm not getting any fire from my coil. I've tested and change both the ignitor and coil but still get no fire to the coil. I need help. The car was running but missing and all this started once I pulled the distributor to check all the wires, ICM and coil. Once I re installed the distributor, I have no fire and have check everything I can think of.
Thanks
Brian
Old Sep 20, 2013 | 05:30 PM
NZXTInerTia's Avatar
Default Re: ECU Testing
I'm fairly sure there is a CEL for a bad ECM.
Old Sep 21, 2013 | 04:42 AM
holmesnmanny's Avatar
use this site to test your ignition system
http://techauto.awardspace.com/
you should first check for power at the distributor it should have power when the ignition is switched on...the ecu toggles the ground side
rollinswapshop
Mar 16, 2011 07:43 PM
rollinswapshop
Mar 15, 2011 03:11 PM
kickz
Jan 4, 2007 06:43 AM
civicjdmb16a
Oct 13, 2006 06:26 PM
JDubsLoPro
Jun 9, 2006 11:26 AM
