Oil pan leaking at bolts
Old Sep 20, 2013 | 01:22 AM
94 IntegraLS's Avatar
Default Oil pan leaking at bolts
So recently I replaced my oil pan and the gasket but I've noticed that there's 2-3 bolts that oil seems to be seeping through because the heads on the bolts have oil on them. Everything is torqued down to spec and i really don't wanna try tightening the bolts more. Has anyone ever had this happen? It sucks with the colder weather coming an I can smell a slight oil burning smell when I come to a stop through the cents when I have the heat on.
Old Sep 20, 2013 | 02:21 AM
jdmjunkieXL's Avatar
Did u use hondabond??
Old Sep 20, 2013 | 02:59 AM
Fliptard's Avatar
Default Re: Oil pan leaking at bolts
is this an OEM or at least a Felpro gasket? the ONLY spots you need to use Honda bond are at the seeming for the Rear main seal cover and oil pump. There is a sequence in which the pan needs to be torqued, if u just tighten bolts in whatever order, it will leak.
Old Sep 20, 2013 | 06:42 AM
I used permatex sealant on the specified locations an the bolts were tightened in a criss cross pattern as specified. I seem to have a slight leak on the 2 bolts right above the y pipe but none of the other 20+ bolts seem to be leaking. It's a felpro gasket not oem.
Old Sep 20, 2013 | 06:54 AM
Fliptard's Avatar
once u have the 4 corner nuts finger tight, start at the middle back and use a short 3/8 ratchet and slightly snug up each bolt in a counter clock-wise rotation. just barely snug them up each time, you will have to go around the pan and do this 3-4 times until they are all tight. the gasket should not squeeze out from between the pan and block.
This is specified in the OEM Helms manual.
jayupark
Dec 3, 2013 06:07 PM
sivikvtec
Honda CR-V & Element
Dec 26, 2011 05:44 PM
bopbop93030
Jul 4, 2009 06:40 AM
fackyou
Sep 8, 2006 02:29 PM
O16581724 5 2 5
13
Aug 2, 2005 04:49 PM
