Ballistic1350's turbo eg hatch build
Old Sep 19, 2013 | 08:25 AM
ballistic1350's Avatar
So I scooped up a new DD because I couldn't stand my old automatic ford focus... huge piece of junk. Bought it off a friend who drove it up to me from Georgia. I'm still working through its issues.
The paint looked horrible and had the ugliest green wheels, however in its defense had an ls swap... but a bunch of ebay crap for the turbo setup
It ran rough and needed alot of love so I removed the damaged wastegate and put a new one on an elbow, fixed the TPS sensor, put in a 02 sensor since it had none, replaced the fuel filter, replaced my speedo, and a bunch of routine maintenance. Car was tuned on crome pro and made 235whp. REALLY slow in my opinion.
Anyway enough of the back story and on to where I'm at now.
Things for the new setup, all is sitting and waiting:
Block:
B18a RS machine open deck block
84 mm manley pistons
turbo tuff rods
ls crank
ARP mainstuds
ACL bearings
Moroso oil pan
ARP headstuds
ATI damper
Goldeneagle headgasket
Gates timing belt
OEM water pump
OEM oil pump
Head:
Ported GSR Head
Supertech Springs
Ferrara Valves
Bronze guides
Skunk2 Pro 1 cams
AEM cam gears
Skunk2 ultra street intake manifold
Skunk2 74mm throttlebody
Trans:
LS trans for now
Comp stage 4 clutch
Comp flywheel
Stock axles for now
Ignition:
Hondata COP
New distributor
NGK plugs
Turbo:
Ball Bearing STC Reaper from TheShodan with high temp coating on exhaust housing
Go-autoworks Ramorn with high temp coating and downpipe
Tial 44mm wastegate
Full 3" exhaust
DEI titanium wrap and turbo blanket
Fuel:
ID1000 injectors
Walbro in tank pump
Aeromotive FPR
Skunk2 composite rail
Random:
T1 breather setup with 2 ports on front of valve cover
15lb braille to be relocated to bumper
Power steering and AC removed
Koyo rad
13" Spal fan
Will be running hondata s300 with BBG since I have the solenoid and push lock fittings for it all
As soon as I get home I'll upload current pics since I spraybombed the car blue after sanding off most of the surface rust and painted the wheels white. Honestly the car looks like crap but I don't really care since I need to take it to a body shop to remove the rear quarter rust and paint it. That can wait till I get the motor and tune sorted.
Old Sep 19, 2013 | 08:45 AM
Default Re: Ballistic1350's turbo eg hatch build
I'm also contemplating as to whether the hondata cpr would be a worth while investment... opinions?
Old Sep 19, 2013 | 09:29 AM
Just got done ordering an ATI damper from Titanmotorsports since my used block came without a pulley. great deal and said they'd have it to my door in 3 days!
Old Sep 20, 2013 | 12:24 PM
So here is my spray bombed car, looks rough I know...
Old Sep 20, 2013 | 12:28 PM
The block I picked up from a member on here came like such... not naming any names but wtf! Good thing I had it shipped straight to my machinist to pull apart and check everything
Old Sep 20, 2013 | 02:17 PM
bks84's Avatar
Loved
seems like a decent start...
Old Sep 20, 2013 | 04:24 PM
Yeah I'll agree with you there. The new motor is supposed to take about 2 weeks to be disassembled and checked. I'm also looking into what turbo I want to run, since I got the 5857 prior to the motor... and well things spiraled out of control a bit.
I've been pm'ing the Shodan about a ball bearing Reaper and am leaning towards it. I really want a 500 whp car on 93 pump, however that magic number is not really set in stone.
Old Sep 22, 2013 | 06:22 AM
Well started to rip it all apart in preparation for the new setup
Old Sep 24, 2013 | 03:03 PM
91-lsvtecsi's Avatar
Looking good!!! But whoever shipped that block didnt give a **** smh!!!! LOL Keep us posted!
Old Sep 26, 2013 | 05:47 PM
Just bought a ball bearing STC reaper off the Shodan! Pretty excited about it, now someone buy my journal berating billet 5857 so I can afford more stuff!
Old Sep 26, 2013 | 06:55 PM
boostlsveg's Avatar
nice build
Old Oct 2, 2013 | 04:19 PM
So I ordered a STC reaper turbo and since it needs water lines I decided to upgrade my radiator. So I got a koyo rad, koyo cap, and spal fan. It has provisions for my water lines, Thanks go to The Shodan for the hook up.
Nice piece btw
Old Oct 2, 2013 | 04:33 PM
Figured I'd finally take some pics... since everyone wants to see stuff
My intercooler, Tial Q BOV, and go-autoworks ramhorn
ATI damper
Fuel setup: aeromotive filter and fpr, fragola ptfe line -8 and -6, and fittings
And last but not least skunk2 ultra street manifold and 74mm throttle body
Old Oct 2, 2013 | 04:40 PM
If anyone knows of a good bodywork shop around Philly area that doesn't charge an arm and a leg, it would be appreciated.
Newish to the area/ Honda scene so if anyone wants to wrench/ hangout or needs a hand let me know.
Old Oct 4, 2013 | 02:57 PM
Made some progress today, hopefully will have the rest of it out tomorrow. Maybe I'll spray the bay and clean up some of the suspension components while the stuff is out. Called the machine shop earlier this week and they'll start my block next week!
Old Oct 6, 2013 | 03:51 PM
Motor is out!
Old Oct 6, 2013 | 03:52 PM
And a pic just because...
On a side note I noticed pretty much every bushing and ball joint is shot on the car, not so happy about that
Old Oct 7, 2013 | 06:21 AM
Ordered some Moog ball joints, upper control arms, and tie rod ends to replace the damaged pieces.
Hopefully i can borrow a pressure washer to thoroughly clean the engine bay
Old Oct 7, 2013 | 04:43 PM
Upper control arms ended up being discontinued...
So I got the control arm energy suspension kit
Old Oct 11, 2013 | 04:50 PM
Got my motor today! I'll snap some pics when it stops raining
Old Oct 18, 2013 | 07:32 PM
Sorry pic is crappy but here it is
Not sure what I'm going to do with the valve cover... opinions?
On a side note I'm going spend the weekend doing suspension work since I couldn't convince anyone to come help me install the motor
Old Oct 31, 2013 | 05:07 PM
Couple of quick updates
So just so everyone knows you need 9 bolts for aftermarket pressure plates, vice 5 for stock, so I got some arp bolts. I've been waiting on getting someone to help me put the motor back in... wish I could lift it myself.
Got some updated pictures of the STC Reaper I ordered. Both it and my exhaust manifold were sent out to get coated. They look great if I do say so myself!
Old Oct 31, 2013 | 05:12 PM
And a pic of my new skunk2 fuel rail, which actually fits my ID1000s. Long story short my old inline pro fuel rail was drilled out to 14mm and I din't realize it, so I thought I had the wrong injectors since the ID1000s just slid into the rail and wouldn't have sealed at all.
T1racedevelopment actually helped me figure out my issue, so thanks guys!
Old Nov 1, 2013 | 09:27 AM
gutted-dx's Avatar
Nice start man. I'm interested in how that manifold preforms on boost, what are your plans for the car?
Old Nov 1, 2013 | 10:03 AM
Its really just going to be a street car, may have plans for the strip once we settle down and get a full garage, but till then street monster. I love how it looks like crap and it's gonna be able to walk on 95% of the cars on the road
