Swapping trunk lids on two 1991 Accords
Old Sep 18, 2013 | 04:24 PM
Seaside123's Avatar
Default Swapping trunk lids on two 1991 Accords
Hey guys, I've joined the site since acquiring my first 91 Accord. Since then I've come into the possession of another Accord of the same year and color, except this one is a 4 door compared to the 2 door I first purchased.
The 4 door does not run at this point. While it starts, there is some serious white smoke coming out the back, and I do not really wish to track down the problem as this was purchased for $300 as a parts car for my 2 door.
At this point, I am just wanting to swap out all the parts I can.
The 2 door has a big dent in the trunk lid where the previous owner backed into a pole or something. While it shuts and is 90% leak proof, I want to change out the trunk lids, as well as the steering wheel and front headlights.
Is there anyone who can tell me of the easiest way to go about swapping the trunks? I will tend to the other issues after this is taken care of.
Sorry if this was already discussed, but I could NOT find any help on the actual removal/replacement of the trunk lids.
Thanks!
Old Sep 18, 2013 | 07:51 PM
jdowen2's Avatar
Default Re: Swapping trunk lids on two 1991 Accords
I am not sure but I doubt if they are interchangeable. Measure them to be sure.
Old Sep 19, 2013 | 05:45 PM
Seaside123's Avatar
They are the exact same dimensions
Old Sep 19, 2013 | 07:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Pretty sure the coupe/Sedan decklids are the same between the respective years of CB and CD Accords. Since you have both cars it would probably just be easier to unbolt the two decklids and verify if they do indeed fit. Four bolts and maybe some adjustment of the latch, wha-la.
Old Sep 20, 2013 | 06:17 PM
Seaside123's Avatar
Thanks for the replies guys, but I managed to get the trunk lids swapped after carefully removing the latch and all the wiring for the lights. Took about an hour.
Now onto swapping the headlights and steering wheel B)
efiftythree
Jun 6, 2020 01:14 PM
Shadowsstrife
Apr 21, 2017 06:51 PM
dan_g
Apr 8, 2017 11:25 AM
rubenmed
Nov 25, 2012 01:46 AM
chiaxi2002
Jul 22, 2010 10:45 PM
