Buring oil up top(lots of white smoke)
94 gsr. w/bolt ons and tuner 2 cams.
I always liked how my car NEVER smoked/burnt oil up top 7K+ RPM's now it's starting to blow out lots of white smoke I DO have a magnaflow cat however the rest is completely straight piped as in no resonator or muffler. Either way rings or seals I will compression test it again when I get home last time it pushed 230-240 1-4 cyls. wet test made it jump by 10psi or so. i'm hoping seals vs rings
could be a lot of humidity in the air
white smoke is always water or some form of water turning to steam. that could be a blow HG or it could be condensation or humidity in the air
if you aren't losing any coolant there's a better than average chance that the earth is more to blame than your car
if you are losing coolant...well..warped head, warped deck or both
Ut doesn't always do it btw and yes there's always water in the exhaust. will do a dry/wet test once I get home for the weekend just to see. it's always leaked oil never burnt it lol.
Redprelude98
Nov 25, 2008 10:42 AM
