shifter pulls hard when i accelerate?
Old Sep 18, 2013 | 10:33 AM
Cashmoney061596's Avatar
Default shifter pulls hard when i accelerate?
So today I noticed that when i shift or when i accelerate, my shifter is pulling forward, what feels like at the bottom of the shifter, and there is a loud knock like there's two things hitting against each other. Is there potentially something wrong/broken/worn out/missing with my shift linkage or anything in that system?
thanks in advance!
Old Sep 18, 2013 | 10:51 AM
doood's Avatar
been there done that
Default Re: shifter pulls hard when i accelerate?
check the linkage bushings under the car for wear
Old Sep 18, 2013 | 12:17 PM
EpHatchy's Avatar
motor mounts good?
Old Sep 18, 2013 | 06:49 PM
Runnerdown's Avatar
Yeah this is a sign of tired and or broken engine mounts.
Old Sep 19, 2013 | 05:28 PM
Red-Rocket's Avatar
I'm doing a swap into my CRX which did the same thing you described, when I pulled off my mounts, my drivers side was holding on by a sliver of rubber, and my passenger side trans mount, the rubber fell out, front mount was fucked, the only one in decent shape was my rear because I had replaced it with a mount filled with polyurethane.
TAKE IT FROM ME UNBOLT AND CHECK YOUR MOUNTS!
Mark671671
Honda S2000
Oct 26, 2012 08:26 PM
blasterman87
Oct 23, 2009 05:45 PM
Hatchman98
Mar 20, 2007 10:59 AM
AzntstyleZ
Feb 9, 2004 11:33 AM
kahren
Sep 28, 2001 06:16 AM
